Help..
Old Aug 17, 2004 | 02:46 PM
majorpayne1303's Avatar
Default Help..
How do I add pictures to this so I can ask which looks better for my car.. my body kit on or off. I have pictures of both looks so all I need to do it post them on here so I can get feed back.. any help with my stupidity would be great. thanks
Old Aug 17, 2004 | 02:49 PM
purplegsr's Avatar
Default Re: Help.. (majorpayne1303)
Go to a site like http://www.photobucket.com or http://www.we-todd-did-racing.com, sign up for an account. Upload your pictures to the account, it will have an IMG address to use. Click on the little picture icon next to the fonts on the H-T Posting page, insert that IMG link in between those two bracketed IMG tags.
LIKE SO:
[ img]http://i.myspace.com/98/88/1208889/16109773_m.jpg[/img ]
hollis's Avatar
Default Re: Help.. (purplegsr)
body kit off
Old Aug 17, 2004 | 02:52 PM
I have a myspace account with pictures on there.. you can view the pictures from this link...
http://profiles.myspace.com/users/2417781
let me know if it works or not.
Old Aug 17, 2004 | 03:00 PM
Ok I think i got it.. now.. body kit on or off..
P.S. I only have one more post allowed today. Im on trial
Old Aug 17, 2004 | 04:27 PM
3.504's Avatar
this is totally an opinion, but... body kit off, loose the headlights, drop it some more and throw the jdmshit lip on
Old Aug 17, 2004 | 05:13 PM
G1 TEGGY's Avatar
Default Re: Help.. (3.504)
third post i've seen today like this, this needs to go in the appearance and cosmetic forum only, for every/any car... honda-TECH.. that means the "Integra" forum is for integra TECH questions, please be more careful
Old Aug 18, 2004 | 07:26 AM
Default Thanks...
Just wanted to thank everyone that helped me with the pictures and letting me know if the body kit should stay on or go off.
Old Aug 18, 2004 | 07:42 AM
Default Re: Thanks... (majorpayne1303)
I have another question. My 93 integra has a b18b motor with an automatic tranny (yes i know.. need to go manual..) anyways. When I took it to carslbad the weekend they closed I ran a 17.4 My friends where telling me that I would have had a much better time if My launch was quicker.. All of my low end torque is gone but once my car reaches about 4500 it pulls like crazy. Does anyone know what the problem could be? off the line its slow untill I hit 4500 when the cars in first. I just recently changed my spark plugs to NGK spark plugs and changed my o2 cencer yet again and it still didn't help. Im also only getting 150 miles to the tank. Please let me know what I should do to improve my gas mileage and also help get all of my power back in my low end and high end torque. thanks
Old Aug 18, 2004 | 09:02 AM
purplegsr's Avatar
17.4 sounds about right for an 93 GS (you should have a B18A motor unless you did a swap?) with a crappy launch. What was your 60 foot time, trap speed, and 1/8th time? That will help to diagnose whether it was a bad launch or engine problems. It's probably a combination of both. My 92 LS is slow as *****, and 5 spds with no mods usually pull in the mid-16s. I can see an auto doing a 16.9 or worse.
Second issue, if you are getting 150 miles per tank, that just sucks. I have a 92 LS (same motor) with 138k miles, and I easily get 300 miles per tank ~ 30mpg. Do you do a lot of city driving, idling in traffic, etc? You should consider looking into maintenance in order to improve that issue - new fuel filter, new dist cap and rotor, make sure your tires are inflated to the correct psi, valve lash adjustment, injector cleaning, throttle body cleaning. Those are probably the culprits of bad mileage unless you are throwing other engine codes (is your check engine light on?).
Old Aug 19, 2004 | 01:18 PM
Default Re: Thanks... (purplegsr)
Yes I did do a swap. Im currently running a B18B with crappy launch. my time slip read like this
car 72
.610 reaction
2.888 60 ft
7.584 330 ft
11.374 1/8 et
65.43 1/8 MPH
17.459 1/4 ET
81.08 1/4 MPH
about the gas miliage. I do alot of freeway travel. I drive about 50-60 miles a day on freeways. 25 to work and 25 back. plus maybe 5-10 on street. when Im on the freeway i do about 85-90 the whole way(unless theres a cop) I have a new fuel filter and new dist car and rotor. My tires are new aswell and sit at about 44 PSI. they rate 52 in the front but 44 in the back. My injectors just got cleaned. and trottle body may be the only thing I havent done yet. My check engine light is off.
Brandon
Old Aug 20, 2004 | 08:59 AM
purplegsr's Avatar
Well, a 2.888 60 foot will definitely slow your time. If you had a normal 60 foot time, like 2.0 or a little lower, your time would be closer to mid-16s, which is respectable I guess. When you went to the B18B did you switch to a hydraulic trannsmission?
As for the mileage, man, I just don't know. You seem to have taken care of everything, I am thinking there is something wrong with your fuel pump, timing, valve lash, or else something more than routine maintenance. Oh yeah, just to let you know, don't run the PSI ratings for the tires printed on the outside of the actual tire, use the manufacturer's recommendations on the door jamb of the car. Usually these range between 29-35psi, I think 52 and 44 are way too high.
Old Aug 20, 2004 | 09:10 AM
G-bonic's Avatar
Hijacked
body kit off, of course keep it jdm, stock.. well unless if u are FAST AND THE FURIOUS fans keep ur body kit on...
Old Aug 20, 2004 | 10:08 AM
vtec69's Avatar
Wow thats a really crappy run
When I had my 93 civic with the stock motor I ran better than that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by majorpayne1303 &raquo;</TD></TR><TR><TD CLASS="quote">Yes I did do a swap. Im currently running a B18B with crappy launch. my time slip read like this
car 72
.610 reaction
2.888 60 ft
7.584 330 ft
11.374 1/8 et
65.43 1/8 MPH
17.459 1/4 ET
81.08 1/4 MPH
Brandon
Old Aug 20, 2004 | 10:36 AM
Chris_Bye's Avatar
Default Re: Thanks... (vtec69)
take the kit and headlights off, slam it, and get a manual b16 tranny. It'll look good and pull hard.
Old Aug 20, 2004 | 01:06 PM
Default Thanks..
Im still running the stock tranny. I found a honda civic with a del sole SI swap made. Its a 5 speed and has a nitrous tank in it with 17 inch rims.. do you think i should buy this car?.. ill post pics as soon as I get them. Thanks for all of your help..
Also when I run the manufactors PSI the tires look really deflated and it squiels around turns and stuff. So shouldnt I keep it at like 42 or something?
Old Aug 24, 2004 | 11:26 AM
Default Re: Thanks.. (majorpayne1303)
Found out my tranny was so bad that when they took it out of the car peices were falling out of the tranny.. bults and bearings and other ****.. just fell straight out on the floor. OUCH damage... is 3400 dollors.. just on rebuilding a tranny. Why cant parents learn.. its cheeper to get a new tranny with ecu and other stuff for 50 bucks.. oh well..
Old Aug 24, 2004 | 11:33 AM
Sack Master's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr &raquo;</TD></TR><TR><TD CLASS="quote">Well, a 2.888 60 foot will definitely slow your time. If you had a normal 60 foot time, like 2.0 or a little lower, your time would be closer to mid-16s, which is respectable I guess. When you went to the B18B did you switch to a hydraulic trannsmission?
As for the mileage, man, I just don't know. You seem to have taken care of everything, I am thinking there is something wrong with your fuel pump, timing, valve lash, or else something more than routine maintenance. Oh yeah, just to let you know, don't run the PSI ratings for the tires printed on the outside of the actual tire, use the manufacturer's recommendations on the door jamb of the car. Usually these range between 29-35psi, I think 52 and 44 are way too high.</TD></TR></TABLE>
I don't think a mid 16 second fwd car has the nuts to pull a 1.9 60ft. Maybe on slicks. But I would just laugh at that one.
CWalsh
Other Make Vehicles
Nov 23, 2014 04:54 AM
metal craft
Welding / Fabrication
Aug 7, 2006 06:55 PM
h22teg
Feb 13, 2005 09:19 PM
CoLdpLayJDM
Oct 24, 2004 07:00 AM
spettinger
Audio / Security / Video
Jun 28, 2003 02:28 AM
