help!
Old Oct 28, 2003 | 06:48 AM
93g2teg's Avatar
Default help!
can someone please list all the components that make up our suspension (for a DA6). i plan on upgrading all my suspension cuz my car is 10 years old. thanks
Old Oct 28, 2003 | 07:07 AM
TEXN3's Avatar
Default Re: help! (93g2teg)
i don't own a DA6, i own a DA9. and unless you imported your integra from japan, then you have a DA9.
what you'll want to upgrade is bushings, shocks/springs, change to a 22mm anti-roll bar, rear lower and upper tie-bars. and maybe a front upper tie bar. you'll be all set and with the larger anti-roll bar...you'll lose a lot of understeer.
i don't think you need to upgrade the control arms, they will last and are aluminum. my teg is 13 years old and the suspension is mostly stock except for a lower tie bar from g2ic member ben ogle. it handles fine and is still fun, but starting to get a little body roll now.
if you haven't yet...check out http://www.g2ic.com it is a gen2 specific forum and you'll get a little more help there.
93gunner
Jun 2, 2007 04:17 AM
gosu08
May 10, 2007 05:21 PM
jacob1217
Mar 26, 2007 12:51 PM
Flux
Aug 11, 2002 03:03 PM
nakashima79
Mar 20, 2002 09:52 AM
