Help.....
Old Jun 19, 2009 | 03:20 PM
SUPERSONICBLUR's Avatar
New User
Default Help.....
Hey guys and girls . I have a problem with my integra . I drove it about 2-3 weeks ago and it drove just fine , i've never had a problem with the motor or the tranny . But the other day i go to get in and take it for a drive and it wont go into gear ( any gear ) . When the car is off it goes into gear just as smooth as it did the day it drove off the acura lot . But once the car is on , i cant even force it into the gears . Any suggestions on what could be wrong with it ? Thanks in advance .
Old Jun 19, 2009 | 08:53 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Help.....
https://honda-tech.com/forums/acura-integra-6/creating-new-topic-choose-subject-specific-title-not-help-me-asap-2477272/
Old Jun 19, 2009 | 09:46 PM
teggyboy's Avatar
No one can really help you with anything unless you describe clearly what is actually wrong. When and how it happened.
We don't even know what you are driving. We don't know what engine, mileage, and so on.
With what you said in your post, your clutch is probably out.
Old Jun 20, 2009 | 05:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Most likely the clutch is not disengaging. Could be your master cylinder, could be the slave cylinder, could be the throwout bearing, could be the release fork or any number of other things.
Old Jun 21, 2009 | 12:20 AM
MilanoCpe's Avatar
check for leaks under your clutch pedal. IMO it might be your clutch slave cylinder and/OR master cylinder causing the problems.
Old Jun 22, 2009 | 03:17 AM
New User
cool thanks ill check into all of those options above .
Djole_V
Feb 12, 2008 10:12 AM
517vwj_boi
Mar 14, 2006 09:35 PM
candy eg
Jan 25, 2006 06:41 AM
candy eg
Jan 23, 2006 08:02 AM
candy eg
