HELP
Old May 26, 2008 | 02:44 PM
BUILTandBOOSTED's Avatar
Default HELP
i just got my 98 integra GSR built and got my 60-1 turbo kit put on. the guy that did it said he tuned it rich so that when the motor got broke in that it would lean itself out. he didnt put new spark plugs in come to find out. i was still running Iridiums. i was having problems with it yesterday, when i was driving it for a while, i let it cool, then turned it off. i ran into the store and then it would barely start and it wouldnt stay running until i let the engine cool down for a while. it sounds like it is running on 3 cylinders or less, sputtering and barely running until i keep it revved up and get out on the road. when it gets above about 3k rpms it quits doing it. so today i changed the spark plugs and put in colder ones and it still is doing it. anybody know whats up?
Old May 26, 2008 | 05:03 PM
mr.beeks's Avatar
Default Re: HELP (BUILTandBOOSTED)
u could use a resitor pack for your injectors (find them on 90-91) integra.
also sounds like timming is an issue do you have sparks on all cylinders how much boost are u pushing
Old May 27, 2008 | 07:17 AM
Default Re: HELP (mr.beeks)
i do have spark on all cylinders and right now im running 8 psi until i get a different map. whats weird is that it doesnt do it when i start it up for the first time in the day. it does it only when it has been running for a while then i turn it off and try to restart it.
Old May 27, 2008 | 07:18 AM
bump
Old May 28, 2008 | 10:08 AM
bump
Old May 31, 2008 | 01:04 PM
bump
Old May 31, 2008 | 02:13 PM
A L I A S's Avatar
does it have difficulty starting up?
Old Jun 1, 2008 | 10:42 PM
Default Re: HELP (A L I A S)
it has difficulty starting up after its been running for a while but when i start it for the first time in the day its fine. after its been running for a while and i try to restart it, it turns over real slow and i have to hold it open throttle for it to start and if i let off the gas it dies. and while its running it sounds like its running on 3 cylinders until i rev it up
Old Jun 3, 2008 | 02:30 AM
bump. anybody please?
didder
Dec 5, 2008 08:37 AM
Used2beAb16
Mar 2, 2005 09:19 PM
V3locity
Honda Motorcycles
Apr 3, 2003 12:29 AM
