heating problem
i have a 94 acura teg. its got a gsr block and a b16 head. the other day the car over heated, i let it cool down and added water. drove it for about 30mins, turned it off " on the cluster it marked that it was ok"... here it comes!!! later that day i went to start the car and the lights went out on the cluster...??? so that was just a fuse fixed it the next day, BUT ONE PART OR THE CLUSTER WAS NOT WORKING AND IT WAS TEMP SIDE, DROVE THE CAR FOR ABOUT 45 MINS AT 60 MPH. AND THE LITTLE METER RISE AT ALL...??? SO WTF???? I CHECKED THE FUSES AND NOTHING????? IM THINKING ITS THE TEMP SENCER, but what do you guys think it is??????
help
and ya, it does still over heats
help
Its got to be the sensor, check it, the plug might had just come off, or the wires might be frayed. Is the fan kicking? When was the last time thermostat was changed? If fan is kicking and thermostat has been changed check the ground wires.
i just put a thermostat in march. and the fan is not kicking.....................................?????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ???????????????
$amGD3
Jul 26, 2010 09:24 AM
HondaMan_TypeR
Jan 6, 2009 05:04 PM
