heat issues
Old Feb 9, 2014 | 01:30 AM
Zac W.'s Avatar
Default heat issues
I replaced the thermostat in my 99 LS with an OEM Honda thermostat. When I'm driving I'm usually around 190 degress. When I stop or sit for awhile I drop to 150 degrees and I do not get much heat blowing out of the vents. Do I have air in the system? Or something else?
Thanks ahead of time.
Old Feb 9, 2014 | 04:09 AM
kaycee_00's Avatar
Default Re: heat issues
Did you bleed the system after you installed the new thermostat?
Old Feb 9, 2014 | 04:34 AM
Zac W.'s Avatar
The only thing I did was I let the car run with the radiator cap off until I saw the fluid drop then added more until it was full. If you are refering to something else, then to answer your question, no. I do not have a service manual. How do you go about doing this?
Old Feb 9, 2014 | 07:07 AM
tamboo's Avatar
10 Year Member
now you have a service manual.
http://www.spooledupracing.com/downl...a/Integra_RSX/
Old Feb 9, 2014 | 07:16 AM
kaycee_00's Avatar
That should help you ^. It may be beneficial to jack the front of the car up and turn your heater on during the bleeding (which is the process you've done already). Sometimes it take a few tries to get every thing out.
Old Feb 9, 2014 | 05:57 PM
Zac W.'s Avatar
Thanks for the manual. I will give it a try.
Fuzbal
Honda Civic (2001 - 2005)
Jul 9, 2011 09:39 PM
rockenuptown
12
Jun 9, 2007 10:51 AM
prayalot
Jun 3, 2007 12:15 PM
briq4
Mar 4, 2006 02:10 PM
JV
Apr 19, 2002 01:22 PM
