Headers question
Old Feb 9, 2006 | 10:54 AM
IHeartRicers's Avatar
Default Headers question
I was just wondering whats the difference between the 4-1 headers and the 4-2-1's. Which increases performance more? Thanks.
Old Feb 9, 2006 | 11:00 AM
Type_R_Kills's Avatar
here we go again..............
Old Feb 9, 2006 | 11:06 AM
EJ1 Freak's Avatar
Default Re: (Type_R_Kills)
4-1's are generally better for more top end power!
If you don't wan't to give me an answer, don't post worthless things like "here we go again". I'm sure there was a time where you didn't know the difference.
And I probably should just google it or something, but its much easier for me to understand from other people.
Old Feb 9, 2006 | 11:35 AM
b20integrapower's Avatar
Default Re: (IHeartRicers)
the reason he said here we go again is becuz this has been covered 5023948230948 times...and searching would yield the answer you are looking for
took me 1 minute
https://honda-tech.com/zerothread?id=1455208
Old Feb 9, 2006 | 03:33 PM
RS_91's Avatar
Default Re: (b20integrapower)
Old Feb 10, 2006 | 06:57 AM
Sorry but that still doesn't tell me what the difference is. No one seemed for sure, and no one said what makes one a 4-2-1 and the other a 4-1.
Old Feb 10, 2006 | 07:02 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHeartRicers &raquo;</TD></TR><TR><TD CLASS="quote">Sorry but that still doesn't tell me what the difference is. No one seemed for sure, and no one said what makes one a 4-2-1 and the other a 4-1.</TD></TR></TABLE>
wtf do you mean "what makes one a 4-2-1 and the other a 4-1"!??
4-2-1 -&gt; 4 pipes that go into 2 pipes that go into 1 pipe
4-1 -&gt; 4 pipes that go into 1 pipe
which one is better? well, that's up to you and what you want out of your car. don't expect to be spoonfed this info.
Old Feb 10, 2006 | 07:05 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHeartRicers &raquo;</TD></TR><TR><TD CLASS="quote"> I'm sure there was a time where you didn't know the difference. And I probably should just google it or something, but its much easier for me to understand from other people.</TD></TR></TABLE>
there was a time when we didn't know, but that's exactly right...looking for yourself is the best way for YOU to learn.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">the reason he said here we go again is becuz this has been covered 5023948230948 times...and searching would yield the answer you are looking for
took me 1 minute
https://honda-tech.com/zerothread?id=1455208</TD></TR></TABLE>
point made.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nuck Chorris &raquo;</TD></TR><TR><TD CLASS="quote">
which one is better? well, that's up to you and what you want out of your car. don't expect to be spoonfed this info.</TD></TR></TABLE>
To attempt to answer your question, I understand that a 4-2-1 makes a bit more low end than a 4-1 header. Notice most high end headers are 4-1? They're built for midrange and top end. Sorry to not have anything SOLID, but that's the best I understand.
Chris
Old Feb 10, 2006 | 07:29 AM
PrinceAli132's Avatar
Default Re: (DAantagonist)
http://www.team-integra.net/se...ID=50
http://www.team-integra.net/se...eID=2
Read these articles, they discuss everything from 4-2-1/4-1, effects from bigger diamter, longer tubes, sequentially paired primaries, collector size differences, "stepped" header and its effects of reversion, and a lot more.
Ali
Old Feb 10, 2006 | 11:01 AM
Thanks Ali, what I was looking for.
Old Feb 10, 2006 | 02:51 PM
ernald711's Avatar
Default Re: (RS_91)
they both add power, but each is designed to get more power at different rpm ranges. get a good researched header and it'll do you good. doesn't matter if it's name brand, as long as it was designed well. a no name 4-2-1 well designed will make better numbers than a 4-1 that was slapped together.
Adankid
Oct 6, 2008 02:43 PM
mc_civic213
May 7, 2008 06:04 PM
commguy
Aug 5, 2007 02:09 PM
zxc4
Jul 27, 2005 08:28 AM
you2envious
Feb 6, 2002 06:55 AM
