headers?
Old Apr 10, 2006 | 02:23 PM
elesvtec's Avatar
Default headers?
hey guys I have a 94 integra. Its 93 ls bottom with a jdm b16 head. I want to get headers. What year headers and for what model. Do I get a gsr,ls or b16 headers? Or will it not matter. Well get back with thanx.
Old Apr 10, 2006 | 02:36 PM
integra95gsr's Avatar
welcome to HT, i see its your 1st post! before anyone makes this a huge deal ill help ya out. its a inline four cylinder engine, having only one (1) header. not header's...lol since you useing the b16 head, i would suggest going with a header made for the b16. but dont mark my words on this, i know there are some headers that wont match, and also some length issue's. located in the top right of your screen is a RED link, that say's "search" this is your best friend. make sure you search the Archived section aswell. as this topic has been covered numerous time's. good luck!
Old Apr 10, 2006 | 07:23 PM
Ruben19's Avatar
Get a 4-1 header.
Get a B18c or gsr header
B16 wont fit. Too short.
Old Apr 10, 2006 | 07:34 PM
purplegsr's Avatar
Default Re: (Ruben19)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 &raquo;</TD></TR><TR><TD CLASS="quote">
B16 wont fit. Too short.</TD></TR></TABLE>
This is correct. The b16 runners will be too short to go around the taller LS block/oil pan. You can get a header for a LS or GSR, the main factor should be what kind of exhaust you are using. If you have the stock exhaust (or a 94-01 LS aftermarket exhaust system) currently, you should get a 94-01 LS exhaust (all of them will have a longer collector than the 94-99 GSR and will have an o2 bung in the collector). A 4-1 will be good if you don't care about clearance, but a 4-2-1 does the job as well, and you won't be scraping/denting it if your car is low.
One thing though, if you don't mind having a low hanging exhaust, and are willing to do some exhaust piping customization, you should go with a JDM ITR 4-1 (DC makes a copy, as do several other ebay companies). It has a longer 2.5" collector, and is a good low cost alternative, as long as you don't mind getting a 2.5" flange welded onto your cat or test pipe, or getting a high flow cat.
Old Apr 10, 2006 | 07:55 PM
elesvtec's Avatar
Default Re: (purplegsr)
thanx, you helped out alot, now I can go bid on the right one on ebay now.
Rev Red
23
Aug 22, 2007 11:09 AM
B bOy CrAyOn
Dec 16, 2006 05:59 PM
honda06si
15
Aug 16, 2004 05:30 PM
BigZ88
Dec 7, 2003 12:29 AM
TakeMeOverThere
Nov 25, 2002 12:24 AM
