Header porting
Old Aug 25, 2004 | 12:19 AM
Mikizzle's Avatar
Default Header porting
I got a 98 jdm itr 4-1 header that i got rewelded at the runners. The problem is that the welds went through so when you look at the inside of the runners, you see little droops of weld that went through. I heard of people porting out their header a little more then stock. I was wondering how much i would have to port it out, Also am i albe to just use a high powered dremel tool to port it out myself. thanks
Old Aug 25, 2004 | 12:49 AM
3.504's Avatar
Default Re: Header porting (grn4drgsr)
use a dremel and grind away the welds. dont take any material away from the tubes.... it'll weakin it and make it prone to cracking when it goes through heat cycles.
Old Aug 25, 2004 | 05:57 AM
StyleTEG's Avatar
Default Re: Header porting (3.504)
Taking 1mm off of the flange area will help create a lip at the head and prevent reversion.
Black R
Jul 5, 2007 09:42 AM
Chaze*R
Oct 19, 2005 03:30 PM
brnyrdcmndo
Feb 3, 2005 01:52 PM
Spoonin
Jun 13, 2003 08:38 PM
nerdish
Mar 3, 2002 07:10 AM
