Header Decison?
some say dcsport, other say obx, and my buddy says use the jdm type r header (keep in mind this is for my 94 gsr) which would i recieve the most benifical power from? i know that the jdm is 4-2-1 but so is the dcsports any opions on this subject.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MD94GSR »</TD></TR><TR><TD CLASS="quote"> i know that the jdm is 4-2-1 but so is the dcsports...</TD></TR></TABLE>the jdm itr header is actually 4-1 design with a 2.5" collector, as is the jdm dc sports version.
here is a header buying guide you should check out first.
none of the above....u wont gain any real HP with a header on a pretty much stock motor. Save your money and learn to drive your car well with the power you have. Then come up with a goal of what you want your car to do then look into modifications. Adding power is ussually the last step in modifying a car. But if you must spend your money buy the JDM ITR header good luck
Mike Ockhurts
10
Oct 21, 2004 03:58 AM
Rratedcivichatch
Dec 26, 2002 10:43 AM
