header bolts part #
Old Oct 10, 2003 | 12:13 AM
oMek's Avatar
Default header bolts part #
i need new header bolts like 3 of mine are broke. i read on here that i could use slave cilinder bolts.
i need the part # from
http://www.acuraautomotiveparts.org
thanks for the help
Old Oct 10, 2003 | 11:54 AM
oMek's Avatar
Default Re: header bolts part # (oMekone GBPDC2)
anyone please
Old Oct 10, 2003 | 12:13 PM
P1mpSlap's Avatar
honda #90001-P30-003 off a 00si
Old Oct 10, 2003 | 12:19 PM
oMek's Avatar
Default Re: (P1mpSlap)
those will work for a gsr?
Old Oct 10, 2003 | 12:23 PM
Vitt1's Avatar
I have one header bolt sitting right here as a matter of fact.
Honda part # 90026-PE0-000
This is the 2 part threaded bolt that bolts into the block, and the other part is for the header nut. Not 100% sure from the drawing on the link above, but it is the bolt where item #14 is indicating (99729). If that's it it's very cheap. Hope it helps.
P1mpSlap's Avatar
yeah
I'm pretty sure the thread pitch is the same on all DOHC heads. Honda usually uses most of the same type of stuff on all of their engines.
Old Oct 10, 2003 | 12:24 PM
Vitt1's Avatar
Default Re: header bolts part # (Vitt1)
Mine are for the GSR.
Old Oct 10, 2003 | 01:18 PM
db8sirg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap &raquo;</TD></TR><TR><TD CLASS="quote">honda #90001-P30-003 off a 00si
Old Oct 10, 2003 | 01:51 PM
oMek's Avatar
Default Re: (db8sirg)
so part # #90001-P30-003 is for 1 stud and 1 bolt. and i need like 10 right?
Old Oct 10, 2003 | 03:13 PM
db8sirg's Avatar
Default Re: (oMekone GBPDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekone GBPDC2 &raquo;</TD></TR><TR><TD CLASS="quote">so part # #90001-P30-003 is for 1 stud and 1 bolt. and i need like 10 right?</TD></TR></TABLE>
no its the part number for the one header bolt. if you want the nut and stud those have different part #s. and you only need 9 bolts or studs and nuts.
Old Oct 10, 2003 | 03:48 PM
IN VTEC's Avatar
That's the part number for the exhaust manifold bolts. You'll only need 7 of them. The two on the ends are normally studs/nuts.
I recommend using the two studs on the ends and using the bolts on the 7 in the middle. It makes it a lot easier to mount the exhaust manifold/header if you have just the two on the ends as studs.
Old Oct 10, 2003 | 04:07 PM
oMek's Avatar
Default Re: (IN VTEC)
so i need to order 7 of that part #?
Old Oct 10, 2003 | 04:16 PM
db8sirg's Avatar
you got it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oMekone GBPDC2 &raquo;</TD></TR><TR><TD CLASS="quote">so i need to order 7 of that part #?</TD></TR></TABLE>
Old Oct 10, 2003 | 04:17 PM
IN VTEC's Avatar
Yes.
Old Oct 10, 2003 | 04:40 PM
oMek's Avatar
thanks guys
Old Oct 10, 2003 | 08:29 PM
darrinbrewer's Avatar
i broke 1 of my gsr's header studs...pulled one out of a 92-95 dx 1.5 head..same part..
MumBleZ_94gsR
Apr 23, 2009 10:29 PM
free99
Dec 31, 2007 01:26 PM
Prudz_lude
Mar 29, 2007 01:18 PM
MI4$DC5
Nov 27, 2006 06:55 AM
Maireeka
May 17, 2006 07:33 PM
