header bolt ?
Old Dec 23, 2004 | 10:04 AM
orion840's Avatar
Default header bolt ?
does anyone know who makes headerbolts that are
extended i have a broken bolt after putting on a header
and what extended studs for going turbo later on
i know arp makes lots of stuff like that but
i am having trouble finding info on it
Old Dec 23, 2004 | 06:57 PM
orion840's Avatar
Default Re: header bolt ? (orion840)
so does anyone know the answer
Old Dec 23, 2004 | 07:13 PM
Quitripin's Avatar
let me guess did it break at the left side where the vtec solenoid is?
Old Dec 23, 2004 | 08:33 PM
orion840's Avatar
Default Re: header bolt ? (Quitripin)
yea the greddy header has a thick flang
yea its the left one but it does not leak
i want to fix it next week but im having
trouble finding the parts i need
i could buy stock honda but whats
the point i want something stronger
i have seen extended studs on some cars
but cant find out where they got them
Old Dec 23, 2004 | 09:08 PM
LSvtec03's Avatar
there's really no market for stronger header studs. either go buy another oem one, or go to any hardware store and get another stud or a bolt. doesn't really matter.
Old Dec 23, 2004 | 10:36 PM
AlienKrOZ's Avatar
Default Re: header bolt ? (LSvtec03)
mines broke also at the same spot near the vtec solenid but mines is a LS tho. how do u get those out?
Old Dec 23, 2004 | 11:40 PM
Quitripin's Avatar
Default Re: header bolt ? (AlienKrOZ)
for some odd apparent reason it seems to always break at the same spot, It happened to 3 of my motors (2gs-r and 1si).
Old Dec 24, 2004 | 12:06 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin &raquo;</TD></TR><TR><TD CLASS="quote">for some odd apparent reason it seems to always break at the same spot, It happened to 3 of my motors (2gs-r and 1si).</TD></TR></TABLE>
just a coincidence. i think it's because you have the most room to tighten with that bolt being that nothing is in the way, making it easy to overtighten. the space you have for all the others is a little more restrictive.
Old Dec 24, 2004 | 06:16 AM
orion840's Avatar
so i guess arp does not make anything
i did use a torque wrench on the bolts
but after i had installed it i went for a
drive then came back and checked all
the bolts with the wrench but as soon
as i put the wrench to it it just broke
off i didnt even use any presure
Old Dec 24, 2004 | 06:42 AM
incredteg3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlienKrOZ &raquo;</TD></TR><TR><TD CLASS="quote">how do u get those out?</TD></TR></TABLE>
well if you have enough thread (doesn't sound like you do) you can take two nuts on 1st one upside-down then the other normal then tighten them agenst eachother then you can loosen it however if all of you threads are gone then I would take it to my machine shop (CWPence) and have them do it (prob. drill it out).
Old Dec 24, 2004 | 07:08 AM
orion840's Avatar
Default Re: header bolt ? (incredteg3)
or u can get an angul head drill
and drill em out
Old Dec 24, 2004 | 08:08 AM
Quitripin's Avatar
i noticed my buddy who has a 2001 gsr has two bolts instead of studs for each side. His car doesn't have any mods on his car and he bought it from the dealership with it
Old Dec 24, 2004 | 11:07 AM
fro's Avatar
fro
u can drill it out and get an ez out bit and get it out that way, thats what i did for mine.
Old Dec 25, 2004 | 07:43 AM
orion840's Avatar
Default Re: header bolt ? (fro)
yea im know how to get them out
but i cant find any like arp extended studs
but i have seen em on other peoples
rides
Old Dec 25, 2004 | 10:49 AM
Big Teggie's Avatar
ARP does make longer studs...
http://www.arp-bolts.com/media...8.pdf
The stock stud is 37mm long. However a set of 10 ARP studs is like $80.
Old Dec 25, 2004 | 10:51 AM
2bars's Avatar
try this http://www.lightningmotorsports.com
Old Dec 26, 2004 | 08:04 PM
orion840's Avatar
Default Re: header bolt ? (2bars)
none of those links said what the bolts were called
does anyone know tha size or part number
i think i will try and give em a call
Old Dec 26, 2004 | 09:28 PM
Big Teggie's Avatar
I sent you a direct link to the studs ARP sells. Find a dealer and buy them.
The stock stud is M8x1.25 and 37mm long.
Old Dec 27, 2004 | 12:40 AM
importdude2000's Avatar
when i have time im gonna change all of em out for bolts
these things are too weak
Old Dec 27, 2004 | 01:26 AM
BlackSage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin &raquo;</TD></TR><TR><TD CLASS="quote">i noticed my buddy who has a 2001 gsr has two bolts instead of studs for each side. His car doesn't have any mods on his car and he bought it from the dealership with it</TD></TR></TABLE>
My 00 gsr is the same way.
Old Dec 27, 2004 | 07:04 AM
orion840's Avatar
Default Re: header bolt ? (Big Teggie)
thanks for the info
lilo_goki
Jun 9, 2008 12:18 PM
TheAccordGuy
Jun 27, 2006 08:24 AM
92integraVTECgsr
Feb 15, 2006 10:57 AM
ebelp
Jul 29, 2003 10:21 AM
EF_LSVtec
Oct 3, 2002 06:30 AM
