header
Old Jul 26, 2003 | 11:04 AM
BulliztyK's Avatar
Default header
i just install my 4-1 DC header.
the promblem is i think igot a leak between the header and the cat, it sounds like
a hole in the muffler noise. any one know how 2 fix that promblem
or any one have experience this promblem before.
help it sounds like sh*t
Old Jul 26, 2003 | 11:11 AM
P1mpSlap's Avatar
get a new gasket for the cat
Old Jul 26, 2003 | 11:15 AM
BulliztyK's Avatar
where can i get gasket from or
can i put gasket sealer around the end pipe
and then connect the pipe to the cat?
wat do u think
Old Jul 26, 2003 | 11:24 AM
BulliztyK's Avatar
any sugestons out there i know alot of people have put on header before
Old Jul 26, 2003 | 11:54 AM
BulliztyK's Avatar
fu*k i strip the bolt to the cat
can i use any kind of bolt or do i need the
bolt that the spring bolts 2?
Old Jul 26, 2003 | 04:47 PM
SMC Integra's Avatar
Default Re: (BulliztyK)
You can use any bolt, just as long as you get the downpipe and cat to seat together correctly.
My bolts were too rusted, so i took some that were threaded all the way up and just slapped those on. Worked fine. Not sure if the springs are truely necessary though.
Old Jul 26, 2003 | 05:03 PM
Lord Helmet's Avatar
Default Re: (SMC Rice Rocket)
no you don't need the springs but it's there for the vibration coming from the engine. any bolts will do as long as it's long enough. the best bet for a gasket is the local muffler shop.
Old Jul 26, 2003 | 07:34 PM
xteg95's Avatar
Default Re: (sleeperciv)
just wondering but did you even put a donut gasket on the header? if you dont got one goto a dealer or like the other guy said a muffler shop.
Old Jul 27, 2003 | 01:24 AM
BulliztyK's Avatar
got the dounut cumming,
will that stop the noise that im hearing?
also will that dounut fit on the DC 4-1 header?
im just curious hoping that it will fit
what do you guys think
Old Jul 27, 2003 | 04:22 AM
skunkintegra's Avatar
dont know which donut gasket you bought??
pretty sure you need 2.5 inch....
if that isnt what you got... Dave "SMSP" on this board can get them for $13
but that should clear up your problem.
p.s. - BulliztyK https://honda-tech.com/zerothread?id=571774 possible meet for sd, mn, nd, ne, and ia!! check it out!
Old Jul 28, 2003 | 01:28 AM
BulliztyK's Avatar
i got the donut from checkers
is that right
Old Jul 28, 2003 | 09:25 PM
mowry's Avatar
Default Re: header (BulliztyK)
I am having EXACTLY the same problem with the DC Ceramic 4-2-1 header. I HAVE the gasket, and it STILL leaks. Starting to **** me off. Mine has a bit of an alignment problem (had to shove the cat around a lot to get things to mate) and removing the block hanger for the second section seemingly has no effect. Does your DC header line up to the cat properly, or is it a little off? I saw an article some months back in Grassroots Motorsports that they had the same problem, but I can't find it now...
Thanks for your input
Matt
Old Jul 31, 2003 | 01:24 AM
BulliztyK's Avatar
yeah my header is is not line up right either
its a little slanted, but i got the 2 bolts 2 go through. i dont know what size the donut is,
they say its a oem fit 4 the civics and integra
so does that mean it fits, on the DC 4-1 header
94gsr_vtc
Aug 7, 2004 08:19 AM
Thrillhouse
Jul 4, 2004 10:18 AM
ActiveAero
Mar 9, 2002 03:38 PM
hYpE-R-29
Nov 2, 2001 07:14 PM
NSX Bob
Oct 17, 2001 11:02 AM
