which header??
Old Mar 25, 2009 | 06:36 PM
beutler09's Avatar
Default which header??
im looking at getting a new header but just doing some research first. what is better 4-2-1? or just 4-1? i would guess 4-2-1 would be better flow right?
Old Mar 25, 2009 | 07:25 PM
SIR EF9's Avatar
Default Re: which header??
Naw man 4-1 is the best... Check out the jdm itr thats what im running...
Old Mar 25, 2009 | 07:53 PM
Brice.Hayden's Avatar
depends on what you have done. a 4-1 might not net you anything since you have a stock motor. if you have a built motor it will yield the most highend HP. the 4-2-1 will net you more power on a stock motor. either way, whats your reasoning for adding a header?
Old Mar 25, 2009 | 08:40 PM
SIR EF9's Avatar
Idk what he has but i have the corresponding motor for my jdm itr headers...
Old Mar 25, 2009 | 09:53 PM
redGSRguy's Avatar
Cuz everyone else is doing it. What other mods and plans do you have for your car?
Old Mar 25, 2009 | 10:02 PM
JdmTypeRdc2's Avatar
Its never good to add something just because everyone else is doing it...you should look at what overall goal you have for the motor and go from there.
A 421 would yield better results when dealing with low to mid range torque while a 41 would help you in the higher end.
Collector size is also important, so you should also look at that.
Supporting mods such as what exhaust you plan to use is also helpful...
Dont just get something cuz everyone else is doing it...in the end it might not help you at all. Concentrate on your power goals and take it from there.
Old Mar 25, 2009 | 10:09 PM
1992db2's Avatar
yup, 4-1 gives you top end, 4-2-1 is for bottom end. i wouldnt run 4-2-1s unless it was on a non-vtec. I have the JDM ITR headers on my B17 and i love the top end and how they look completely stock with the heatshield.
Old Mar 25, 2009 | 10:38 PM
SIR EF9's Avatar
^^^^^^totally agree
Old Mar 26, 2009 | 11:22 AM
beutler09's Avatar
hmm thats kind of surprising to me... anyways my current set up is 81mm low compression pistons in a b16a2 block and b18c1 head. ITR intake. as for exhuast its stock headers obviously 4-2-1 with test pipe, still have resignator to rs-r muffler.
i plan on getting higher compression pistons next and may remove resignator. and sooner or later playing with the head
Old Mar 26, 2009 | 04:37 PM
acura_integra-gs's Avatar
I would get a Itr header there awsome and look awsome
Old Mar 26, 2009 | 09:14 PM
1992db2's Avatar
ITR header, test pipe, and exhaust. This will give you awesome gains
Old Mar 26, 2009 | 09:29 PM
omnirage's Avatar
These threads are hilarious.
Unless you're really into your car and will have it tuned, just waste your money on something your friends will like. Mad props son!
Old Mar 27, 2009 | 12:29 AM
DuongBros.'s Avatar
proper tune is keyyy
Old Mar 27, 2009 | 11:38 AM
beutler09's Avatar
thats why i didnt say "hey i just got a gsr im and i got 200 bucks i think ill put a header on"
if you can't tell its a project in progress. currently i have a P28 with electric tune but i plan to get it completely re tuned.
jc2801
11
Dec 29, 2007 07:58 PM
slow_db7
Oct 9, 2007 03:59 AM
BXk24ek9
25
May 21, 2007 07:21 AM
96redgsr
11
Aug 26, 2003 03:22 PM
Rratedcivichatch
Dec 26, 2002 10:43 AM
