head torque
Old Jan 28, 2009 | 02:38 PM
gonmaro's Avatar
Default head torque
how tight should the I tighten the head down on a boosted LS? I have ARP studs that have been tighten once but not ran, I have a Cometic head gasket and going to plan on running around 280 HP. Stock is 63 ft.lbs. Should i go any higher?
Old Jan 28, 2009 | 02:51 PM
leteg98's Avatar
Default Re: head torque
I think you torque arp head studs less than oem. Search and you can probably find out.
Old Jan 28, 2009 | 08:12 PM
mouab18c1's Avatar
Arp head studs have specific torque specs. Are you using thr arp moly lube with your studs?
Old Jan 29, 2009 | 09:00 AM
TIMMY4TOES's Avatar
torque the head bolts in the proper sequence. and then i would re-tighten again with my torque wrench to make sure they are to spec
Old Jan 29, 2009 | 09:48 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
ARP has literature on their website regarding torque specs, I believe. However I would contact them and verify if they are okay to use after being tightened once before but the engine not run since then.
Old Jan 29, 2009 | 12:05 PM
wunfstgsr's Avatar
Loved
Community Favorite
https://honda-tech.com/forums/showth...ight=how+build
he recomends 67 ft lbs with molly lube i always use this guide..
avotegra
Dec 27, 2015 01:26 PM
hawaii_boi_808
Jul 14, 2008 07:08 AM
Jdmb16sir2
Jun 10, 2007 05:50 PM
roger93si
Jan 16, 2007 10:12 AM
NorCalHB
Dec 1, 2002 10:37 PM
