head gasket problem
Old Jul 12, 2004 | 05:48 PM
B18C-VTI_R's Avatar
Default head gasket problem
since everyone is talking about head gasket, i think i need a new head gasket as well, because my oil seems to leak around that area. or above the distributor. and honda in nz said i need to replace the seel or gasket or some ****, honda ppl recond they are almost industratble
Old Jul 13, 2004 | 06:08 AM
JimBlake's Avatar
Default Re: head gasket problem (B18C-VTI_R)
The head gasket is well below the distributor. Do you think maybe it's leaking from the valve-cover gasket or cam seal? That would be a lot less complicated...
Old Jul 13, 2004 | 01:17 PM
alfee's Avatar
Default Re: head gasket problem (JimBlake)
its probably your valve cover seals or the circle seal on the head facing the distributor n not the head gasket.
Old Jul 13, 2004 | 01:23 PM
genetsang's Avatar
Default Re: head gasket problem (alfee)
do what the posters said above first.
changing a valve cover seal or cam seal is a lot easier than ripping the whole head apart.. and only to find out at the end, it was not the head gasket
civicvtec16
Oct 29, 2006 10:45 AM
fujiwara takumi
Jul 29, 2006 12:26 PM
Chuethou_b18c5
May 1, 2006 11:51 PM
Blanket Jackson
Sep 12, 2003 09:43 PM
RTW DC2R
Sep 25, 2002 08:05 AM
