Having Starting prblems Help
Old Aug 19, 2005 | 05:49 PM
mericbe's Avatar
Default Having Starting prblems Help
Hey guys, well let me give u a heads up. I have a 94 Civic Coupe DX w/ a B18B1 for the heartbeat (DOHC 1.8L non V-tec) and run'n w/ GSR Tranny. Was using a OEM Dist w/ a MSD External Coil, but now using a Moroso Dist. Remapped ECU, Skunk 2 Short Throw, Greddy Evo 1 Catback, dropped with 1.8 Suspension Techniques springs w/ KYB struts. The problem: I was having some dist. problems to begin w/ for example: car wouldnt start ( all lights motor didn't turn over), but then would start on like 2 or third try. Heavy wear on rotaty buttons, seemed it had to be brand new to start. Replaced and stated just fine like 3 times. Changed Ign Control Module in Dist, bought brand new from Acura Dealer. So I thought it was the coil so put MSD External Coil on ran fine for a couple months. Then the car wouldn't start at all after a couple weeks I changed the the relay located on driver side I think it was the Main Relay? Bought brand new, it started. After a couple month's clutch went out. Let sit for a month to save money for clutch. Started car and it ran fine let warm up since it hasn't run in while. Let it cool down replaced clutch in like an hour or 2 in driveway, bolted everything up, checked all hoses, sensors, and fluids. Start car but nothing, all lights but no turn over. So WITH THE CAR TURNED ON FUEL PUMP WAS ON AND ALL hooked hot wire to starter still wouldn't start. So I thought is was the dist so I just put a new Moroso on it, but still dead. Tryed the Eng Codes but no help there. I got 21, 92, 51. checked that still nothing. Do you think it could be a clutch switch sensor? . I f you turn key to on pos everything works, turn to start nothing, but starter DOES WORK. Pleases Help
Old Aug 19, 2005 | 06:08 PM
mericbe's Avatar
Default Re: Having Starting prblems Help (mericbe)
PLEASE HELP!
89civicguy
Aug 17, 2008 05:06 AM
mericbe
Aug 19, 2005 05:36 PM
904d
Mar 23, 2005 09:41 PM
94_CRVtec
Jan 6, 2005 11:48 AM
