Having problems Can you help...
Old Feb 20, 2004 | 07:39 PM
icedoutteg's Avatar
Default Having problems Con you help...
All the interior lights in my teg and the tail lights have all gone out. So I have changed all the fuses and checked the wiring but everything seems to be fine. But I still have no lights. So can someone please help? I am still learning when it comes to wiring.
Old Feb 20, 2004 | 08:21 PM
Creep's Avatar
Default Re: Having problems Con you help... (icedoutteg)
Do you have a meter? If your sure its not the fuses, it's gonna be hard to figure out whats wrong without one.
Old Feb 20, 2004 | 08:38 PM
typeR#0427's Avatar
Default Re: Having problems Con you help... (Creep)
Last time this happenend to me, it was a fuse. I had just overlooked it. I also noticed that the door latch was not closing right, and it got stuck shut, therefore making the lights on the inside not turn on. Good luck. Voltage meter is a good start after that.
Old Feb 21, 2004 | 05:15 AM
Creep's Avatar
Default Re: Having problems Con you help... (hamB18C1)
Yeah.. check your fuses again.
Old Feb 26, 2004 | 09:08 PM
millersteg92's Avatar
dead battery
!!miguel!!
Dec 3, 2016 02:43 PM
LogsTeggy
Mar 29, 2015 04:13 PM
portugino_69
Feb 27, 2007 06:38 PM
khunt0012
Apr 28, 2006 07:35 PM
