Haunted Car! Car tries to start without key?!?
Old 07-31-2008, 04:12 PM
StimpyWan's Avatar
Default Haunted Car! Car tries to start without key?!?
I've tried searching for this issue, with no luck. I've been experiencing starting issues with my stock 94 Integra LS (auto). Specifically, the car wouldn't turn over, so I replaced the battery. That seemed to help for a week or two. Next, the car again wouldn't turn over. This time, I retried several times, and the car finally tried to start, but still wouldn't turn over, and then wouldn't stop. I turned the key off, and the car engine kept trying to engage. I even removed the key, and the engine was still turning over, without starting. I had to disconnect the battery to stop it.
To resolve this, I've replaced the ignition, and had the starter tested, which tested OK. I have a fairly new distributor and ECU, new battery, fairly new plugs and wires, timing belt, O2 sensor, Map sensor, fuel filter and fuel pump!!! A quick wire inspection looks OK. I haven't checked (or re-soldered) the main relay. That's next. Any other suggestions would be greatly appreciated. Thanks!
Modified by StimpyWan at 5:27 PM 7/31/2008
Old 07-31-2008, 04:27 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: Haunted Car! Car tries to start without key?!? (StimpyWan)
The starter solenoid is most likely at fault. The ignition simply sends it a signal and the solnoid switched the high current for the starter.
Old 07-31-2008, 06:22 PM
steveharrmr23's Avatar
Default Re: Haunted Car! Car tries to start without key?!? (Dogginator)
i second dogginator but i would hold off on resoldering and replace solenoid
Old 07-31-2008, 06:23 PM
dcRay's Avatar
Does your car have remote start with your alarm system?
Old 08-01-2008, 06:07 AM
StimpyWan's Avatar
Default Re: Haunted Car! Car tries to start without key?!? (dcRay)
No, no remote starter switch. Also, thanks for the solenoid tip. But, to pardon my ignorance, does this still mean replacing the starter? No way to just replace the solenoid? Thanks again.
Old 08-01-2008, 06:41 AM
steveo135's Avatar
no way to replace just the solenoid on the newer starters like ours...
just replace the starter and that will solve your problem...
i had the same problem on one of my old cars.. i actually had to drive it with the starter still trying to start the engine from where i was to my house because i had no tools to disconnect the battery...
Old 08-01-2008, 11:02 AM
StimpyWan's Avatar
Default Re: Haunted Car! Car tries to start without key?!? (steveo135)
Thanks Guys! It was the solenoid. Picked up a new starter, put it on, and now my Integra starts OK... To cool...
JHipps
10
09-01-2014 11:44 AM
forevermemorabl
08-26-2013 05:26 PM
thambi23
08-12-2007 11:29 PM
junya16
03-01-2003 05:41 PM
Randomlude
10-07-2002 09:47 PM
Quick Reply: Haunted Car! Car tries to start without key?!?
