hatch window trim replacement
Old Sep 29, 2010 | 12:17 PM
komat's Avatar
Default hatch window trim replacement
does anyone know if the trim that goes around the hatch window just pulls off? or do they rip? when you replace the window do you have to get a new one?
Old Sep 29, 2010 | 02:51 PM
JdmTypeRdc2's Avatar
Default Re: hatch window trim replacement
Yes you can pull it off, however, if you really want to make it look better, you can just sand it down, and paint it over. I have done this numerous times to my last two integras, in which these trims were severly faded.
Or you can go to Acura and pay for some new ones. Up to you.
Old Sep 29, 2010 | 09:46 PM
komat's Avatar
they arnt faded or anyting. i just need my hatch window replaced. the shop wasnt sure if the trim would be reusable or not.
Old Sep 29, 2010 | 10:07 PM
Im pretty sure you can reuse it, and they should be able to put it back on along with the new window.
If you wanna get crispy new everything, then just order a new one at Acura. Shouldnt be that expensive...
Old Sep 29, 2010 | 10:36 PM
komat's Avatar
its $150 for a new one
Old Sep 29, 2010 | 11:12 PM
A window install place should be able to reuse the one you have now. Usually they give you the option to get a new one along with the window. Thats completely up to you.
Old Sep 30, 2010 | 09:22 AM
komat's Avatar
went to two shops in town. both side they would require a new trim....
anyone know a good place sells the trim cheaper then $150
Old Sep 30, 2010 | 12:24 PM
Usually where i get my honda parts is online through an actual dealership. They always have everything in stock and shippin is fast, not to mention you dont pay full price.
Try these and see what you can find:
OEMACURAPARTS.com
AcuraOemParts.com
AcuraAutomotiveparts.org
Acurapartsoem.com
Old Oct 2, 2010 | 01:02 AM
k24hatch1980's Avatar
dude the trim comes off,,, make sure its hot outside or you got a heat gun , and it pry it off slow... it may get a lil wavy or messed up, but def reusable... yea i know $150... F that
thats what they are going to do and charge you for a new one,
DazeMS
Jan 21, 2010 05:29 PM
JjuuN R
Oct 6, 2007 03:32 PM
intgraCA
May 27, 2006 01:41 PM
chex329
Sep 2, 2005 06:35 PM
hxtasy
Aug 31, 2005 06:05 PM
