Hatch problem
Old Nov 22, 2001 | 05:14 PM
acuraLSSE95's Avatar
New User
Default Hatch problem
when I open the hatch, I see 2 holes(size of a nickel) one on each side under the base of the spoiler. I see 2 rubber stops in the trunk, similar to the ones under the hood where you use to adjust the height of the hood. I can't seem to fit them back on, the holes are too big. Is there another piece that connect the rubber stops to the hatch?
Old Nov 23, 2001 | 07:16 AM
New User
Default Re: Hatch problem (acuraLSSE95)
anyone??
Old Nov 23, 2001 | 08:41 AM
ndustryalGSR's Avatar
They ought to "screw" back in, similar to the ones up front, as you mentioned. I beleive there are 2 different types of stoppers on the underside of the hatch lid -- the height-adjustable screw type, and the general "pop-in" type that doesn't adjust (which also has a smaller base that fits in the hole). Make sure you've got the right stoppers going into the right holes. I've messed with mine a lot, trying to fix that notorious hatch rattle.
Anyway, good luck with the fix.
zach1288
Jul 20, 2009 12:28 PM
crxsleeper210
Oct 25, 2007 03:11 PM
REDTOPAlchemy
Aug 25, 2004 01:29 PM
99cxrico
Aug 24, 2004 03:09 PM
integ22
Mar 4, 2003 07:48 AM
