Hardware question
Old Feb 10, 2008 | 12:00 PM
chevellion's Avatar
Default Hardware question
After cutting the fused bolt for the rear lower control arm, I am in need of two new bolts with nuts that hold the strut to the lower control arm. If I purchase two new control arms, are the bolts included? Where can these bolts be purchased?
Old Feb 10, 2008 | 12:10 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Hardware question (chevellion)
You can buy the bolts at any Honda or Acura dealer. The part number is 90172-SK7-A01. No, the bolts are not included with the a new control arm.
http://www.sonsacuraparts.com/...dIrno=
Old Feb 10, 2008 | 12:18 PM
chevellion's Avatar
Default Re: Hardware question (Dogginator)
Awesome. I see the chart. However, by the looks of it, the bushing part number is not available? It shows number 10 in the picture as the bushing, but not in the chart. Could you tell me the part number of the bushing as well? Thank you Dogginator.
Kevin
Old Feb 10, 2008 | 06:03 PM
Dogginator's Avatar
Daisy... Daisy...
See item 24 here:
http://www.sonsacuraparts.com/...ch=no
Energy Suspension shock bushings are easier to install because the do not require a press like the stock ones. Have you removed the stock bushings yet?
I used a torch to melt the rubber and then assembled a hack saw through the bushing race to split it. Once split, you can use a punch to drive it out.
Old Feb 10, 2008 | 06:07 PM
chevellion's Avatar
I also used a torch to melt the old bushing on one side. I'll repeat for the other side tomorrow.
Old Feb 11, 2008 | 03:11 AM
Dogginator's Avatar
Daisy... Daisy...
Here are the ES bushings (p/n ENS-16-8103R):
http://store.summitracing.com/...w=sku
shahriar35
Jun 25, 2016 10:38 AM
speedpro92
Dec 22, 2010 08:17 AM
BoostinEJ1
36
Jun 10, 2004 10:54 AM
conesmasher
Mar 20, 2003 11:36 AM
