hard shifting??? HELP!!!!!
Old Dec 3, 2001 | 06:49 PM
integra81's Avatar
New User
Default hard shifting??? HELP!!!!!
i just noticed when switch gears its not as smooth as it used to be. it seems like it happend all of a sudden. It happens in every gear. i dont know how to explain it but it just seems like its "Choppy" goin into gears, like its not smooth goin into and out of gears. what can this be. please help. it really doesnt feel right!!
Old Dec 3, 2001 | 07:49 PM
Regular Series's Avatar
Default Re: hard shifting??? HELP!!!!! (integra81)
Could be several things....you may need a clutch adjustment, or replacement. How many miles do you have on the car? You may also have a problem with your shift linkage. You should also check the fluid level in your gearbox...it may be low.
Old Dec 4, 2001 | 03:23 AM
integra81's Avatar
New User
i have 115k miles on my car
Old Dec 4, 2001 | 04:57 AM
The clutch may be going....
Get a Haynes manual. It should only set you back $10-15, and it's accurate enough for most troubleshooting. It should be able to help you narrow it down a bit.
Ri'can Luder
Oct 16, 2006 11:41 AM
kinvid22
Mar 27, 2005 11:18 PM
ill_defiined
Mar 18, 2005 01:20 PM
integra81
Dec 4, 2001 12:05 PM
integra81
Dec 4, 2001 07:29 AM
