hammered subframe
Old Sep 23, 2008 | 10:31 PM
SkaiWu's Avatar
Default hammered subframe
how many ppl have this happened
i posted in the bay thread and noticed a few ppl have this happen as well
altho i am tucking a little bit, it's because my tires are way too big -gasp- 195/60/15
i am thinking of going 195/50/15 and getting the subframe hammered < (will that cause problems?) it seems a good number do it. i think i'll just have no gap if i go 195/50 and leave height as is
and also is how safe exactly, is having my tires going down like that
the subframe piece i am talking about
what you're looking for is that metal piece back there... i think...
its kinda poking out
gonna smash that **** on friday
Modified by SkaiWu at 9:27 PM 9/24/2008
Old Sep 23, 2008 | 10:42 PM
_RONzDB8_'s Avatar
Default Re: hammered subframe (SkaiWu)
I had the same thing happen to me on 195/50/15...I just hammered the lip that sticks out from under the fender & that fixed my problem...You should get that fixed soon otherwise it might take out bigger chunks from the tire
Old Sep 23, 2008 | 10:44 PM
SkaiWu's Avatar
damn on 195/50 as well? you must be way lower then mine then =P how low?
i'll try it out soon, is there a specific way to hammer it? or straight up? i use a 3lb small black sledge shape rubber mallet right?
i see i have more on the left side which is most likely from bumps and a LITTLE bit on the right side which is most likely from turning the wheel all the way right to make turns up things
Old Sep 23, 2008 | 10:58 PM
_RONzDB8_'s Avatar
Default Re: (SkaiWu)
Yeah, my 99 EM1 was pretty low.
Just bend the lip flush, if you do it straight up it might take longer to do & I just used a regular hammer to do it the outcome did not look good but it did the job
Old Sep 24, 2008 | 10:48 AM
sg's Avatar
sg
Default Re: (_RONzDB8_)
can somebody take a picture of what exactly your banging? that's rubbing into your rubber like that? thanks
Old Sep 24, 2008 | 11:31 AM
steveo135's Avatar
Default Re: (sg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sg &raquo;</TD></TR><TR><TD CLASS="quote">can somebody take a picture of what exactly your banging? that's rubbing into your rubber like that? thanks</TD></TR></TABLE>
x2 bump for better pics
it looks like you have crazy camber
Old Sep 24, 2008 | 01:16 PM
SkaiWu's Avatar
my camber isn't that bad actually
uh just look above your tires and inside the fender theres some peice of metal up there above the cambers i think, i cant really see it myself at this point
Old Sep 24, 2008 | 02:06 PM
CleanLikeJdm's Avatar
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkaiWu &raquo;</TD></TR><TR><TD CLASS="quote">uh just look above your tires and inside the fender theres some peice of metal up there above the cambers i think, i cant really see it myself at this point </TD></TR></TABLE>
Jack the car up, remove the fenderliner if it's not already destroyed lol,
then you'll see the strip coming down.
I've seen a few people saying they made it flat, and it worked fine.
Old Sep 24, 2008 | 04:48 PM
SkaiWu's Avatar
i've been told today to hit it _ then hit it ^ so it folds
well i've went to 195/50/15 tires and i don't think they are tucking so, i don't have a problem do i? cuz these are new tires i just got today and i dont want them being destroyed
Old Sep 24, 2008 | 06:35 PM
SkaiWu's Avatar
updated w/ pics
i'll see if i can get that thing hammered out friday ish
Modified by SkaiWu at 9:26 PM 9/24/2008
Old Sep 24, 2008 | 10:27 PM
ls-low-n-slow's Avatar
i had the same problem it ate one of my tires up
all i did was put the car up on a lift and beat the living crap out of it till it wass flat were it wont cut thru the tire any more
Chris101
Mar 1, 2016 07:42 AM
dc2r01
Apr 23, 2006 12:18 PM
ecahatch
Jan 27, 2006 12:09 AM
Nuts
Feb 25, 2003 02:29 PM
5-SpeedFreak
Oct 26, 2002 09:34 AM
