Half Shaft replacement
Old Mar 20, 2006 | 02:00 PM
gurgle's Avatar
Default Half Shaft replacement
Are there any good writeups on this? I searched, but I couldn't find much.
I rotated my tires yesterday, and I noticed grease all over the inside of the front, passenger wheel. Tracked the source down to a torn CV joint boot. I'm guessing the boot could just be replaced and the joint regreased, but maybe if I have to tear it down I might as replace the shaft? It has 160,000 miles on it after all, so I'd do both sides. From what I've been able to gather, the left and right half shafts are the same part, and there's also an intermediate shaft on the driver's side. Is that correct? Should this intermediate shaft be replaced at the same time as well?
thanks in advance
Old Mar 20, 2006 | 02:07 PM
YEABOY's Avatar
Default Re: Half Shaft replacement (gurgle)
you dont have to replace it. not alot of people eplace that part. just make sure its not grinding or has alot of play. Oh an there are diff axles for left and right the one that goes in the Half shaft has full splines. and the other only has like half of it with a lock ring on the end of it, Hope I helped
Old Mar 20, 2006 | 02:31 PM
gurgle's Avatar
Default Re: Half Shaft replacement (Integ4Life)
It's not grinding. There's still grease all over the joint. I just don't want to tear it down to replace the boot + grease only to have to replace the whole mess in 5k more miles. How much life do people typically get out of those joints?
Old Mar 20, 2006 | 03:01 PM
TurBoTeG's Avatar
the 2 axles are DIFFERENT..replace those....the inermediate shaft just leave alone unless the bearing is shot
Old Mar 21, 2006 | 05:57 AM
gurgle's Avatar
Default Re: Half Shaft replacement (TurBoTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">the 2 axles are DIFFERENT..replace those</TD></TR></TABLE>
any writeups? gotchas?
B_Swapped93
Oct 28, 2013 01:38 AM
MadVladCivic
Jan 22, 2013 12:02 PM
huyvu90
Sep 16, 2004 09:05 PM
biassj
May 16, 2003 03:57 AM
