Half radiator?
Old Mar 19, 2012 | 01:34 AM
batmanfc's Avatar
Default Half radiator?
Would I need to run a half radiator for a turbo setup on my da? I was thinking the full rad would work but I want to be sure.
Old Mar 19, 2012 | 02:48 AM
white4d96's Avatar
Default Re: Half radiator?
Not a DA, but my brother ran the stock full rad on his DC LS turbo without issue.
Old Mar 19, 2012 | 10:11 AM
racebum's Avatar
depends on the manifold and turbo selected. if you use a cast manifold you can usually squeeze a full size. ramhorns will want a half unless you do a lot of modding.
Old Mar 20, 2012 | 06:31 AM
batmanfc's Avatar
Alright thanks. That's exactly what I needed to know. Would any Honda half radiator and fan fit?
Old Mar 20, 2012 | 10:36 AM
GRIM516's Avatar
buy aftermarket aluminum half rad and a slim fan. less space taken lol
Old Mar 20, 2012 | 10:54 AM
racebum's Avatar
if you choose to go half rad, buy the tripple core mishimoto or a fat koyo. with half rads you'll need all the extra cooling you can get
Old Mar 20, 2012 | 11:22 AM
batmanfc's Avatar
Alright thanks. So it doesn't matter just any Honda half rad will work.
Old Mar 20, 2012 | 11:38 AM
fcm's Avatar
fcm
Old Fart
Actually any rad you can get to fit will work, and I agree with racebum, go with a triple core.
Check out Mizu cooling solutions, good quality and very good pricing... http://www.mizuracing.com/
I have this one...http://www.mizuracing.com/product.as...ors&pvid=41993
Here is the Civic 1/2 size... http://www.mizuracing.com/product.as...ors&pvid=41977 ignore the pic, place curser over stock number for specs of the rad. 94
Old Mar 20, 2012 | 11:42 AM
GRIM516's Avatar
Old Mar 20, 2012 | 11:45 AM
batmanfc's Avatar
Would a full rad work with a tubular manifold but not a ram horn. Thanks for all the info I'm just trying to make sure I get everything right the first time.
Old Mar 20, 2012 | 11:53 AM
GRIM516's Avatar
depends on the dimensions.but for the sake of not having to remove everything later just get a half rad with triple core,tht way u have a better choice of manifolds IMO
sorry i didnt answer ur ?? but yes i have seen both manifolds work with full rads...
Old Mar 20, 2012 | 12:07 PM
batmanfc's Avatar
This is more what I'm looking to get.
Old Mar 20, 2012 | 12:27 PM
racebum's Avatar
you're going to buy a manifold that cracks in around a month?
if you can't afford a doc race miniram at a minimum save until you can
Old Mar 20, 2012 | 12:31 PM
batmanfc's Avatar
Alright. I didnt realize they were common for cracking. A friend of mine had it for his current setup but decided to go with something else I thought it was a ram horn but that was what it looked like. I thought of buying it for my turbo build.
Old Mar 20, 2012 | 01:10 PM
Turboteg27's Avatar
dude please dont get that manifold!!! that **** will break in a couple weeks. if its a daily driver just get a cast manifold. their strong and the best bang for the buck. just about all ebay headers break and thats no joke. i welded the wastegate tube back on my buddies ebay ram horn like 3 times. i also had one just like in the pic and every tube broke at the flange. if you want a good tubular header you gotta shell out the cheese. i would get a half size radiator and a cast manifold that way u have plenty of room.
Old Mar 20, 2012 | 02:31 PM
racebum's Avatar
the go autoworks cast manifolds are one of your better bangs for the buck. they also will work with your oem radiator. they flow plenty well for a stock bottom end and don't crack
http://www.go-autoworks-store.com/gobcamaco.html
this is a great deal beings you get the manifold, downpipe and dumptube for $519
Old Mar 21, 2012 | 12:39 AM
GRIM516's Avatar
a big no no lol
Re: Half radiator?
red_crx
17
Jan 10, 2008 09:57 AM
95LSS
Jul 24, 2006 06:35 PM
gsr4doorboostin
Mar 28, 2005 10:09 AM
ThePro
Oct 25, 2003 07:59 PM
Ri5e
Jun 19, 2002 07:47 PM
