H&R Spring Install
Old Jul 31, 2002 | 05:35 PM
rota426's Avatar
Default H&R Spring Install
I am ordering H&R Springs (Stage 1 OE minimal drop) from groupbuy tomorrow morning, and I need to know about installing them - is it possible to do it myself, or if I need to take it to a place will they have a problem installing the parts that I ordered? How much will it cost to have them insalled?
TIA
Nate
Old Jul 31, 2002 | 05:46 PM
Aaron M's Avatar
Default Re: H&R Spring Install (styler7)
most places that i called were charging $100, do it yourself its easy. just goto pepboys and rent a spring compressor, its free. make sure u get it at pep boys its the only ones that works the easiest. get a friend over ull need him to stand on the assembly TRUST ME. overall a spring install is very easy. dont waste your money having it installed by someones else
Old Jul 31, 2002 | 06:24 PM
Tweakmeister's Avatar
Default Re: H&R Spring Install (SilverB18C1)
if you try searching the archived stuff a bit I'm sure you find posts on this.
basically it comes down to having the right wrenches, some PB rust spray (get this stuff!), and then the spring compressor.....the first one or two will go slow, but once you get the hang on it everything should go smoothly.
Old Jul 31, 2002 | 06:27 PM
Aaron M's Avatar
Default Re: H&R Spring Install (Tweakmeister)
took me and my cousin about 6 hours, but we were really screwing around, we could do it in 3-4 easy.
goto autozone and get sum PB Blaster
Old Jul 31, 2002 | 06:39 PM
Smooth-GSR's Avatar
Whats this PB blaster, I'm going to do a spring install soon too. Is it the same as wd-40 and liquid wrench?
Old Jul 31, 2002 | 07:03 PM
Aaron M's Avatar
Default Re: H&R Spring Install (Smooth-GSR)
yes but it works faster and penetrates a lot better
Old Jul 31, 2002 | 07:33 PM
Zulu888's Avatar
what does the PB stand for?
Old Jul 31, 2002 | 07:35 PM
Aaron M's Avatar
Default Re: H&R Spring Install (Zulu888)
i dontt know i dont have the bottle handy. but the can has all these advertisment looking thinngs on it and it has the AS SEEN ON TV logo...cant miss it, it will be next to the wd-40 at autozone
jrivehard
Suspension & Brakes
22
Dec 16, 2008 09:26 PM
ityab0y
Suspension & Brakes
12
Jan 6, 2005 09:37 AM
h22l3wd
Nov 22, 2004 12:27 PM
Beach Accord
Oct 18, 2004 03:09 PM
Isaac
Sep 25, 2001 02:58 PM
