Gsr trouble. dont know whats wrong?
Old 10-30-2008, 04:39 AM
JDM 98 GSR's Avatar
Default Gsr trouble. dont know whats wrong?
i have a 98 gsr and my car has been acting really funny when i start it and go to drive the car is fine until i come to a stop and it will either sdtall or my idle will drop to like 500rpms then rise up. i can figure out what this is because when the the car is completely warm and temperature is right the car will be fine? please help?
Old 10-30-2008, 05:11 AM
weavertime1's Avatar
Default Re: Gsr trouble. dont know whats wrong? (JDM 98 GSR)
Have you done anything to the car lately...any bolt ons, or maintenance?
Old 10-30-2008, 06:17 AM
AWD Terror's Avatar
Default Re: Gsr trouble. dont know whats wrong? (weavertime1)
Sounds like it could be vac related, however things like that don't normally go bad on their own.
As stated above, any recent maintenence?
Old 10-30-2008, 08:38 AM
JDM 98 GSR's Avatar
the car has str cam gears, str fuel rail, fuel presure regulator and unorthadox racing pulleys, all this came wit the car so i didnt put any of it on.the only thing i have changed is the plugs i mean a 98 gsr wit 65k on it for $2,300 ya cant beat it haha
Old 10-30-2008, 08:45 AM
Default Re: (JDM 98 GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM 98 GSR &raquo;</TD></TR><TR><TD CLASS="quote">the car has str cam gears, str fuel rail, fuel presure regulator and unorthadox racing pulleys, all this came wit the car so i didnt put any of it on.the only thing i have changed is the plugs i mean a 98 gsr wit 65k on it for $2,300 ya cant beat it haha</TD></TR></TABLE>
Well I would guess for that price something is wrong with it...got any pics?
Modified by weavertime1 at 10:06 AM 10/30/2008
Old 10-30-2008, 08:58 AM
JDM 98 GSR's Avatar
i mean the car runs fine once its warmed up. i just cant figure out what could be doin this
Old 10-30-2008, 09:41 AM
AWD Terror's Avatar
Hold on. You bought the car for cheap b/c it was doing this?
My guess would be that maybe the timing is off due to the cams not being put in right?
Old 10-30-2008, 09:52 AM
Default Re: (AWD Terror)
Check those cam gears...could be a timing issue. Set them to 0, and then adjust the timing to stock reccomendation. Then see what your idle does. Good luck!
Old 10-31-2008, 08:17 AM
JDM 98 GSR's Avatar
Default Re: (weavertime1)
i bought the car that cheap be cause the kid was goin into the police academy and couldnt have a car like this anymore cuz it had a full body kit.but i put it back to stock. im gonna check my cam gears thankd guys!
Old 11-01-2008, 11:03 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM 98 GSR &raquo;</TD></TR><TR><TD CLASS="quote">i bought the car that cheap be cause the kid was goin into the police academy and couldnt have a car like this anymore cuz it had a full body kit.but i put it back to stock. im gonna check my cam gears thankd guys!</TD></TR></TABLE>
Wow, just wow.
I just went through the academy. Look at my car
Old 11-01-2008, 06:56 PM
siksdb8's Avatar
if it is not timing, bleed your coolinng system.
spray some water (do not use a hose!) on your vac hoses to check for leaks. maybe an exhaust leak?
does the car bog when you drive it at all?
Old 11-01-2008, 09:16 PM
B18CYAAA's Avatar
Default Re: (siksdb8)
$2300 with 65k miles.. you have a dangerous road ahead of you.
Old 11-02-2008, 12:40 PM
racebum's Avatar
Default Re: (B18CYAAA)
i just turned down a 96 LS with 100k for 2k the other day. people are desperate to sell cars these days. this whole issue sounds timing related to me. set the gears to zero and the timing at 16deg BTDC. see if it clears up.
OC_DC2_JDM>EURO
01-23-2011 03:40 PM
S13Morgan
01-27-2010 05:34 PM
93preludeh22
12-31-2003 08:00 AM
Quick Reply: Gsr trouble. dont know whats wrong?
