GSR Starting problem...
Old Oct 6, 2006 | 11:23 AM
acun6699's Avatar
Default GSR Starting problem...
Ok, so my friend has a 94 gsr which has a port and polish job, skunk2 intake manifold, ported throttle body, fuel regulator, Cams, headers and exhuast (thats all i can remember).
Well, he said he had the car on, and it was makin some sputtering noise. so wat he did was disconnect the number 1 spark plug wire from the dizzy. when he did that, the car just turned off. He pluged it back in, and the car never started again.
What could be the problem?
New dizzy cap and rotor?
Starter?
Main relay??
Low battery?
Hope you guys can help him out.
Old Oct 6, 2006 | 11:46 AM
LSracing94's Avatar
Default Re: GSR Starting problem... (acun6699)
check for spark...probably needs a coil
Old Oct 11, 2006 | 11:50 AM
acun6699's Avatar
Default Re: GSR Starting problem... (LSracing94)
Cool, ill tell him to check that.
Anyone else have any suggestions?
Old Oct 11, 2006 | 12:44 PM
CHONCH2's Avatar
i'd do a new cap and rotor at least. check for spark, then check for fuel
Old Oct 11, 2006 | 05:44 PM
LSracing94's Avatar
Default Re: (CHONCH2)
doubt its a fuel problem considering he was messing with the plugs/dizzy
Old Oct 16, 2006 | 11:21 AM
acun6699's Avatar
Default Re: (LSracing94)
UPDATE:
So he replaced the cap and rotor, same problem.
Im gonna tell him to switch dizzys wit someone and see if that would be the problem.
Another thing, i had a crx wit almost the same problem and i had to change the main relay. think that could be it.
Not sure where that relay would be in his DC...know where that thing is?
dc4pssthoy
Oct 10, 2010 10:19 PM
pbzhb
Apr 14, 2008 04:25 PM
1 Fly SI
Audio / Security / Video
May 25, 2007 04:58 PM
integra15
Nov 13, 2004 07:07 AM
Pwolf
Feb 9, 2004 05:33 PM
