Gsr making rattling noise!!!
It just started yesterday and I noticed that it only does it at low rpms , its somekind of rattling and then it goes away at higher rpms.
Re: Gsr making rattling noise!!! (rapid_roy)
not just that it can be caused by a lot of otha things
do a search,
also there is a resent topic on this in the integra forum also, check it out.
do a search,
Re: Gsr making rattling noise!!! (-R-)
could it have anything to do with my clutch? Since my clutch has been gone but just havent gotten a chance to change it
Re: Gsr making rattling noise!!! (CivicSiR94)
Q? dose it start ratteling at lke 3k and stop at 3500 around there +/- if so i have the same problem and apperently my exhaust man. is what is causing all the noise. i took off the sheild and it didn't do ****. i think i need a new one to make it stop so i am upgrading like you should always do when something breaks, make it better not new.
hope it works out for you
Re: Gsr making rattling noise!!! (xaznxboixsirx)
My CRX does the same thing. Starts rattling around 3200 RPMs and stops at like 3400. I think it's coming from where the downpipe meets the cat. My heatshield is removed and it didn't make a difference.
Re: Gsr making rattling noise!!! (Rick)
i have a similar problem and at the same rpms. but when i disconected the cat i still had the sound. then my friend noticed i had a couple inches of play in my timing belt and the noise would come from the head somewhere as the belt slapped at 3k. may not be your problem but is possible. by the way put on a kitchen oven mit and squeeze the exhaust shields while it is on a lift of something safe and rev it up or have your buddy get in the car and rev it.
hey guys...i KNOW WHAT THIS ONE IS>......weee
My GS-R starts rattleing at around 3200 and up to around 3700rpms. I researched this for a few days on the net, and noticed that many people were having the same problems.
I found people talking about how the factory headers, have like a dual type pipe or something like that, where there is the outside pipeing, (not the heat sheild) and then like an inner thin metal, or coating or something like that.
I took my car into an exhaust shop, to have a custom exhaust, and high flow cat put on, and this is what happened.
im standing under the car, next to the exhaust guy, he removes the old cat, and peices of metal, and flakes drop outta the header....seems that the inside coating or piping or whatever the hell it is, erouds/rust/breaksdown, really easy, which causes those peices of metal to sit down there, just ahead of the cat.
At that rpm, the motor creates a lil shake for some reason, and rattles those peices.....
That may not be everyones problem, but that was mine, and i have since noticed alot of people getting it fixed, from takeing care of that exact problem.
i had the same thign in the 3000 rpm range. It was my catalytic convertor so there is no way of knowing man jsut takeit to a mechanice or jsut try listen to the revvs closer.
Radecki
02-25-2013 05:17 PM
pli
11-20-2006 05:12 PM
big-cat
03-22-2006 04:22 AM
