GSR help
Old Oct 22, 2008 | 03:13 AM
meow mix's Avatar
Default GSR water line and vac help pic inside
underside of manifold bolted to the head. there is a port that aims right at a port off the coolant tube.. do they connect? not sure not real proficent with hondas kinda putting together a engine from peices that i didint take apart.. help would be great. cant find a vac diagram on here and i want to make sure they connect i dont want coolant shooting into a vac port on the manifold but i cant find anything else that would go to either just making absolute,.
Thanks
Modified by meow mix at 7:27 PM 10/22/2008
Old Oct 22, 2008 | 06:39 AM
AWD Terror's Avatar
Default Re: GSR help (meow mix)
I would have to say no, but I don't fully understand what part you are talking about. A picture would help. From the sound of it, coolant would be pushed into the exhaust.
Old Oct 22, 2008 | 05:57 PM
meow mix's Avatar
http://s211.photobucket.com/al...h.jpg
the red is my question where does it go? in the book its supposed to go to the green circle.. the pink one is for the pcv but what about the blue one?
i dont get it?
Modified by meow mix at 7:24 PM 10/22/2008
Modified by meow mix at 7:25 PM 10/22/2008
Old Oct 22, 2008 | 05:59 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meow mix &raquo;</TD></TR><TR><TD CLASS="quote"> [IMG][/IMG] C:/desktop/tech.jpg
the red is my question where does it go? in the book its supposed to go to the green circle.. the pink one is for the pcv but what about the blue one?</TD></TR></TABLE>
You can't post a picture from your desktop..
You need to find somewhere to host your image and then post..
Try going to photobucket.com then host your picture
and then insert your image like this [img*]your picture URL here[/img*]
meow mix's Avatar
yeah i put a link
Old Oct 22, 2008 | 06:01 PM
Jimmy's Avatar
Global Moderator
Default Re: (meow mix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meow mix &raquo;</TD></TR><TR><TD CLASS="quote">yeah i put a link</TD></TR></TABLE>
Old Oct 22, 2008 | 06:29 PM
meow mix's Avatar
thank you jimmy
Old Oct 23, 2008 | 12:42 AM
meow mix's Avatar
noone knows eh?
Edwin909
Sep 8, 2012 05:37 AM
crxguy1991
Jul 2, 2012 02:29 PM
Hatecity24
12
Feb 3, 2012 12:15 PM
boostedcivichatchbacksi
May 23, 2004 02:47 PM
youngvedder
Jan 3, 2003 03:24 AM
