Gsr Header On LS
piping size is the same in terms of diameter, but the pipe is a different length. To put it into perspective, you can either run a GSR header, GSR cat, and GSR exhaust on the LS and it should fit perfectly (they need to be from the same time period - meaning 94-99 or 00-01) - or you can use a GSR header and see where the mismatch occurs using LS cat and LS exhaust piping, then modify from there.
you need a gsr cat too, it will be more cost effective to just weld the exhaust piping to fit the GSR header. Also, the measurements from 94-99 and 00-01 GSRs are different, so you would need all 3 parts from the same set of years.
