tranny problem
Old Aug 20, 2004 | 07:10 AM
BLK99VTECR's Avatar
Default tranny problem
earlier today i experienced a problem with my car in which my car would not go into any gears untill i was able to force it into 5th and rev the car up high just to get the car to move without stalling out which did a number on my clutch. Now all of a sudden the clutch pedal is very hard and stiff and i can feel bribrations threw it. The car now goes into all the gears with no problems except for the pedal problem. Can somone give me an idea of what im possibly dealing with so i can plan what direction to head in.
Old Aug 20, 2004 | 07:26 AM
JimBlake's Avatar
Default Re: tranny problem (BLK99VTECR)
You probably had a dragging clutch at first. Maybe you could have pumped the pedal & been all right for a while, but more likely you had air in the lines or a bad master cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLK99VTECR &raquo;</TD></TR><TR><TD CLASS="quote">... i can feel bribrations threw it.</TD></TR></TABLE>
But then you burned up your clutch by starting in 5th. Maybe it'll get a little better with use, but don't hold your breath. You probably need a new clutch now.
Old Aug 20, 2004 | 07:53 AM
BLK99VTECR's Avatar
Default Re: tranny problem (JimBlake)
yea im already preparing for a new clutch, im just hoping it last for a couple weeks so that i can afford to get a good clutch and flywheel combo together and be done with it.
Old Aug 20, 2004 | 07:57 AM
Paulnsx's Avatar
i doubt this is it... but i had a problem once where i was super low on clutch fluid which caused me to have some wierd problems (hard to put into gear, grinding even with the clutch fully depressed). i doubt thats your problem but its worth a shot.
Old Aug 20, 2004 | 08:19 AM
JimBlake's Avatar
Default Re: tranny problem (Paulnsx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paulnsx &raquo;</TD></TR><TR><TD CLASS="quote">... super low on clutch fluid...</TD></TR></TABLE>That really may have been his original problem. That's usually how air gets into the lines.
Tolerating it for several weeks or even a couple months all depends on how bad it's chattering (& your tolerance for discomfort). Don't tear your engine mounts apart... New disk right now might prevent further damage to the flywheel & PP, but if you're gonna replace them anyway...
Old Aug 20, 2004 | 09:21 PM
BLK99VTECR's Avatar
well now it seems like its only more difficult to drive it when i baby it, but once after i get on it hard it seems more normal
.I.Need.Money.
Aug 16, 2008 04:03 PM
B18C5-EH2
21
Nov 12, 2007 04:09 AM
BLK99VTECR
Aug 21, 2004 08:02 AM
BLK99VTECR
Aug 20, 2004 09:24 PM
