GSR HALF SHAFT PROBLEM ON TRANNY SIDE
Old 08-13-2009, 08:18 PM
94 EG GSR's Avatar
Default GSR HALF SHAFT PROBLEM ON TRANNY SIDE
i just rebuilt my friends gsr and we reused the tranny he had and his axles were replaced recently.. car runs great but the half shaft on the tranny side wont lock in all the way.. when you look in the hole there looks like a shaft or pin that sits right behind the splines were the half shaft goes so it makes the axles not go in all the way.. it just hits it and stops.. it looks like it spins w the splines.. the half shaft needs to go in about another 1/4in.. ive replaced these many times before and have never seen this issue.. please can someone help me out..
Old 08-13-2009, 08:40 PM
95DC2GS-R's Avatar
Default Re: GSR HALF SHAFT PROBLEM ON TRANNY SIDE
The 'shaft' you're seeing in the transmission is normal.. I don't know the technical term for it, but stock/non-LSD differentials have that.
Some times they're easy and just pop in, and some times you need to use a hammer on the end to get it to lock in. Try giving it a few good whacks and see if that helps.
Old 08-13-2009, 09:01 PM
94 EG GSR's Avatar
that shaft is blocking it from goin in any further.. i already tried to hammer it in.. its right on the back side of the splines in the tranny but the axle needs to push in about a 1/4in more and it just butts into that piece and stops.. i cant get that piece to move
Old 08-13-2009, 09:07 PM
95DC2GS-R's Avatar
Are you sure you're using the correct half shaft?
Old 08-13-2009, 09:20 PM
94 EG GSR's Avatar
lol.. yes the other one is connected to the intermediate shaft and is in and works perfect
Old 08-13-2009, 09:25 PM
GDD GRAMMAR POLICE
PhantoM.DA's Avatar
Did you read this? lol.
Old 08-13-2009, 09:56 PM
lunalink's Avatar
sure its not an auto half shaft?
Old 08-14-2009, 07:39 AM
94 EG GSR's Avatar
yes its the right half shaft.. we used the same tranny andhalfshafts on the car that were on it before we rebuilt the block.. didnt take apart the tranny or anything.. for some reason it wont slide in all the way and when you look in the whole u can see a rod or pin in the way and i dont know how to move it
Old 08-14-2009, 09:24 AM
GDD GRAMMAR POLICE
PhantoM.DA's Avatar
Is that the "Rod/Pin" you're talking about? If so that's suppose to be there. lol.
Old 08-14-2009, 09:28 AM
civicgsr's Avatar
You may need a new snap ring....or are you sure the snap ring is there?
93sivtec
11-19-2007 02:11 PM
honcrx91si
08-24-2006 02:45 PM
compprat
Honda Civic (2001 - 2005)
07-16-2006 06:40 AM
Kusai.Nihonjin.Desu
10-27-2003 09:54 PM
grey16
08-01-2002 10:58 PM
Quick Reply: GSR HALF SHAFT PROBLEM ON TRANNY SIDE
