Ground Control install!
Old May 14, 2002 | 08:32 AM
1994integraLS's Avatar
Default Ground Control install!
I need installation instructions for Ground Control for 1994 Teg LS, links or whatever you have would be greatly appreciatied
Old May 14, 2002 | 08:38 AM
owen_the_soyboy's Avatar
Default Re: Ground Control install! (1994integraLS)
jack up car.
remove wheels.
remove one bolt at end of each rear lower control arms so you can drop the arm down to remove the rear shocks. 'inside' bolt may be easier.
loosen top and bottom shock bolts.
compress spring with manual compressor or shop can do it on a machine.
reassemble units with GC coilover sleeve spring setup.
bolt back into car.
set height to almost top... that will be almost stock height.
adjust height if needed.
reassemble car, all set bro.
if you need more info you should get a Haynes or Chiltons manual at least....
[Modified by owen_the_soyboy, 12:39 PM 5/14/2002]
teddy_dc2
Suspension & Brakes
Mar 16, 2011 08:51 AM
EL'ation
Jun 10, 2005 05:05 AM
BIG RICH
Mar 26, 2004 02:12 AM
Nader_D
Aug 10, 2003 04:23 PM
trutuner
Jul 5, 2003 10:43 AM
