greddy 2.25 421 or jdm oem 4-1 2.5 header??
Old 07-14-2003, 03:39 PM
1hotintegra's Avatar
Default greddy 2.25 421 or jdm oem 4-1 2.5 header??
im thinkin about either the greddy 2.25 (i think anyone know?) 421 or jdm oem 4-1 2.5 header.. i have a dunk exhaust with 60mm piping which is 2.36 inch... so would it be better to get the greddy 2.25 inch with a 2.25 cat into the exhaust or the jdm 4-1 2.5 into a 2.5 cat into the 2.36 exhaust.. just wondering... also im gettin the greddy header for like 310 shipped .. thanks
Old 07-14-2003, 06:02 PM
xJ.SLOTHx's Avatar
Default Re: greddy 2.25 421 or jdm oem 4-1 2.5 header?? (1hotintegra)
depends if you want more midrange power availability or want more top end? but as for me, id go with the JDM 4-1 if i had to choose between those two.
Old 07-14-2003, 06:35 PM
Snoppy's Avatar
Jdm 4-1 all the way better flow in high rpm's.
Old 07-14-2003, 07:35 PM
TRuST's Avatar
JDM 4-1
I have had both headers. The GReddy will feel strong in the mid-range, but I feel that your money would be better spent on the JDM 4-1 if you intend to build-up NA.
Old 07-14-2003, 09:05 PM
Cro-Mag's Avatar
Default Re: greddy 2.25 421 or jdm oem 4-1 2.5 header?? (TRuST)
jdm 4-1 damn scrait
Old 07-14-2003, 10:34 PM
Default Re: greddy 2.25 421 or jdm oem 4-1 2.5 header?? (Cro-Mag)
but then its gunna get bottlenecked when it goes into the 2.36 piping from the catback... header 2.5 cat 2.5 exhaust 2.36 its not gunna flow good
Old 07-14-2003, 10:50 PM
Loveless's Avatar
if you have a ls you are probably better off wiht 4-2-1
Old 07-14-2003, 11:49 PM
coyotes fan's Avatar
What is your setup?
Old 07-15-2003, 08:55 AM
StyleTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
fyi - the greddy has a 2" collector. There are no true 2.25" collectors for our cars because they are designed to matte up with the stock cat (which has a 2.0" inlet).
The only situation where you want inconsistant exhaust diameter is when you increase the diameter slightly as you get further away from the engine. This is called stepping and prevents exhaust reversion.
IntEGNYC's Avatar
Default Re: (coyotes fan)
by his signature, i think he's running GSR.
whichever you decide, i woudl suggest getting a one peice instead of two.
I am installing a 4-2-1 Greddy one peice header next weekend.
Old 07-15-2003, 10:31 AM
Default Re: (IntEGNYC)
Yeah, by his sig it looks like he might be running CTR cams or better, in which I'd say to definitely go with a 2.5 inch collector header.
Old 07-15-2003, 03:33 PM
mugenracer's Avatar
I have the DC JDM 4-1 with a mugen exhaust which has 2.38" piping, under 3k the car feels a little weak, but above it pulls way stronger than my friends car which has an unknown brand (possibly HKS) JDM 4-2-1 (2.5" collector)header with the same mugen system
Old 07-15-2003, 09:26 PM
Default Re: (mugenracer)
skunk 2 stage 1 cams... so a 2.5 to a 2.36 would be ok?
Old 07-15-2003, 09:32 PM
DOHC B18's Avatar
Location: where having a nice car is a crime..., vA, USA
Default Re: (1hotintegra)
i would do skunk2 stage 2 cams....skunk2 valve springs and retainers but DONT use the skunk2 valves
JDM 4-1 header
Old 07-16-2003, 07:55 AM
Default Re: (DOHC B18)
im done with the head... im doin the exhaust now so a 2.5 to a 2.36 wont be bad
Old 07-19-2003, 08:38 PM
ttt
Old 07-19-2003, 10:26 PM
New User
threatcon13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1hotintegra &raquo;</TD></TR><TR><TD CLASS="quote">im done with the head... im doin the exhaust now so a 2.5 to a 2.36 wont be bad</TD></TR></TABLE> thats what i have and i put down 178 to the wheels...yes ideally a 2.5 to 2.5 would be best but it will still flow w/ a bottleneck.
Old 07-20-2003, 12:14 AM
xteg95's Avatar
i just got a greddy SS and installed it earlier today and i love it, i wouldnt think you need the jdm 4-1 header unless you had at least a 2.5" catback or a hi-flow cat to go with it.
i wrote up a little thing on my install:
https://honda-tech.com/zerothread?id=568086
got it for 272 shipped
redracer1024
04-18-2006 11:24 PM
VTEConly
09-21-2005 09:53 PM
daddymaxx
11-16-2003 09:44 AM
brian b
11-08-2001 05:08 PM
rsx03
08-15-2001 04:22 PM
Quick Reply: greddy 2.25 421 or jdm oem 4-1 2.5 header??
