got 2 problems. need help
Old Oct 23, 2005 | 03:49 PM
D-series ninja
Guest
Posts: n/a
Default got 2 problems. need help
ok so heres my setup on my teg. nothing crazy at all
94 rs. jdm b18c /intake /header / punched out cat/ exhaust chipped 94cx ECU. ( no A/C )
problem #1 ... took it to 8k, grabbed 2nd, and a bolt broke to some pulley and attached bracket on the side of the motor and was just bouncing around on the alternator belt and down in there.
i dont have a picture of the pulley and bracket, but it hasnt effected anything mechanical ( as far as i know so far ) all my belts were still tight and everything. im not exactly sure what it is. something for A/C maybe ?
anyone else had this happen before?
problem #2 ... had vtec just wired up on car( finally stopped throwing CEL for that ) , and header installed today ( not sure if relevant )
i tried to jump the harness with a paper clip to check the code, i made sure the paperclip was pushed as far in as it will go , but it wont flash it just stays constant ( doenst effect the way the car drives or anything to my knowledge while driving ) . it stops throwing code everytime i shut the car off. and comes on about after like 3 min. of driving it
any thoughts ?
Modified by D-series ninja at 6:49 PM 10/23/2005
Old Oct 23, 2005 | 05:45 PM
D-series ninja
Guest
Posts: n/a
up for an answer
Old Oct 23, 2005 | 08:44 PM
D-series ninja
Guest
Posts: n/a
i know someone has to know somethign on this board
Old Oct 23, 2005 | 08:52 PM
stealthdc2's Avatar
Default Re: got 2 problems. need help (D-series ninja)
a paper clip huh, that is different, i usually use a little two prong electrical connector or a small piece of wire. does the light come on when you are supposed to hit vtec, if so, it might be a vaccuum problem, i have never tried it, but try and read the code when the light comes on before shutting the car off.
Old Oct 24, 2005 | 08:30 AM
D-series ninja
Guest
Posts: n/a
no light comes on anyways after just nomral driving after a few minutes, and i cant get CEL to flash. im gonna mess around with it today, car seems to run just fine though.
but any more help / thoughts would be appreciated
beana
Feb 18, 2008 01:34 PM
ExCiViChYbRiD
Jan 12, 2008 08:50 PM
highneo
May 25, 2006 09:06 AM
dirtySOHC's
Aug 15, 2005 11:22 PM
96ex
Aug 7, 2005 03:01 PM
