is this a good idea?
Old Apr 2, 2005 | 02:47 PM
eymnewdc4's Avatar
Default is this a good idea?
i am almost at 120,000 on the clock. ive done no major mods because it is an automatic and my other project is not done. so it is my daily driver. i do plan to swap out for a 5 speed.
what i would like to know. before boost (no more than 10psi) on that many miles .... would it be a good idea to tear down and rebuild my motor? new gaskets ... seals ... little things, clean it up basically. i dont have the money to "build" a motor, but would a re-build be a bad idea?
i just dont know how long these b18s would last under boost at 120k miles.
Old Apr 5, 2005 | 02:16 PM
eymnewdc4's Avatar
Default Re: is this a good idea? (eymnewdc4)
Old Apr 5, 2005 | 02:56 PM
Racermech's Avatar
if you have the money i dont think it would be a bad thing. You could allways shotpeen the rods and get some new pistons and it should hold up really well under boost
Old Apr 5, 2005 | 03:37 PM
eymnewdc4's Avatar
Default Re: is this a good idea? (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">if you have the money i dont think it would be a bad thing. You could allways shotpeen the rods and get some new pistons and it should hold up really well under boost</TD></TR></TABLE>
changed my mind. im thinking 6-7 psi
Old Apr 5, 2005 | 03:48 PM
notstock93's Avatar
If the compression/leakdown test is good, 6-7 PSI wont hurt anything.
Ive heard of a guy with a stock blcok DA that was running 5psi for many years.
Old Apr 5, 2005 | 04:05 PM
Irish Integra's Avatar
IMO it wouldn't be a bad idea to rebuild if you're fitting a turbo. If money is really tight, maybe do as was said above but it would definately be a good idea to fit new rings and gaskets.
Old Apr 5, 2005 | 07:12 PM
eymnewdc4's Avatar
Default Re: is this a good idea? (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">If the compression/leakdown test is good, 6-7 PSI wont hurt anything.
Ive heard of a guy with a stock blcok DA that was running 5psi for many years.</TD></TR></TABLE>
whats 5-7 psi gonna get me .... HP wise. and what kind of fuel management will supposrt an auto? ive not found one.
streetspeed607
Oct 2, 2007 07:31 PM
mySIisLOVE
Mar 9, 2007 09:51 AM
MYSI
15
Feb 6, 2006 02:32 PM
HYREV2NR
Jan 22, 2006 06:58 PM
DLB1994
Sep 2, 2001 03:47 PM
