Gauge Question?
Old Dec 8, 2004 | 10:03 PM
hooddub's Avatar
Default Gauge Question?
I bought a 2000 GSR a few weeks ago. It came with some crappy aftermarket gauges. The guy gave me all the stock parts with the car. NE ways I put the stock gauges back in and now my speedos 10 mph fast. Is there an easy way to get the speedo back to where its supposed to be?
Old Dec 8, 2004 | 10:06 PM
rovigian's Avatar
Default Re: Gauge Question? (hooddub)
Do you have the factory rims on the car? I know aftermarket wheels can throw it off.
Old Dec 9, 2004 | 12:21 AM
hooddub's Avatar
Default Re: Gauge Question? (rovigian)
yes the factory wheels are on.
Old Dec 9, 2004 | 07:55 AM
revilo's Avatar
It could be the speedo cable? Pinched or something.
What if you drive faster? Is it at every speed a differnece from 10 mph or will it rise with higher speed?
Old Dec 9, 2004 | 09:37 AM
hooddub's Avatar
Default Re: Gauge Question? (revilo)
i dont know , my wife was driven in front of me and i was behind in a rental car. i know for sure it does it from 50 mph to 70.
Old Dec 9, 2004 | 09:40 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revilo &raquo;</TD></TR><TR><TD CLASS="quote">It could be the speedo cable? Pinched or something.
What if you drive faster? Is it at every speed a differnece from 10 mph or will it rise with higher speed?</TD></TR></TABLE>
electronic vss, no speedo cable.
Old Dec 10, 2004 | 09:04 AM
revilo's Avatar
Default Re: Gauge Question? (LSvtec03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSvtec03 &raquo;</TD></TR><TR><TD CLASS="quote">electronic vss, no speedo cable.</TD></TR></TABLE>
hmm... then I don't know...
Old Dec 10, 2004 | 09:22 AM
purplegsr's Avatar
When you switched back to the stock guages, how did you go about repositioning the speedometer needle when it came to putting it back into the cluster? Maybe it was slightly off to start with. The VSS could be correctly reading speed, but the needle may not be mounted properly. Is your tach needle correct? It should read 4000 rpm at 80mph.
Old Dec 11, 2004 | 02:45 AM
hooddub's Avatar
Default Re: Gauge Question? (purplegsr (Exospeed))
could somebody give me some numbers? whats the speed in 1st gear at 3000rpms , 2nd gear at 3000 rpms , for example. It would be greatly appreciated.
Old Dec 11, 2004 | 08:38 AM
purplegsr's Avatar
Depends on your tire size, but you can use a calculator online to get rpm and mph based on your gear ratios in each gear. These are the spec for your tranny:
1 - 3.23
2 - 1.9
3 - 1.360
4 - 1.034
5 - .787
fd - 3.0
In 5th gear, your speedo should read 4000 rpm for 80mph, 3000rpm for 60, 2000rpm to 40. It's pretty much a 2:1 ratio when in 5th. That is assuming stock tire size.
Old Dec 14, 2004 | 09:45 PM
hooddub's Avatar
Thanks!
Old Jan 1, 2005 | 02:01 AM
hooddub's Avatar
well i finally got my car back from the body shop after a month. according to these numbers my speedos right . maybe they fixed it , i dont know. thanks for the info.
Old Jan 8, 2005 | 01:29 AM
hooddub's Avatar
ok this sucks its reading 80mph at 4000rpms in 5th but its still off. Ive clocked speeds with 2 diff. cars and its still reading 10mph fast. Is this ever gonna end.
Old Jan 8, 2005 | 01:36 AM
virusiidx's Avatar
my speedo doesnt 'kick-in' until i hit around 10mph for some reason. It's like a delay for about 3-4 seconds, then it starts to read the mph. Can anyone solve this?
crxaddikt
Mar 27, 2014 07:48 AM
IceCat
Jan 24, 2008 06:58 AM
Muffler Bearing
Honda Motorcycles
13
Mar 11, 2006 09:10 PM
rainmanef
Jan 28, 2004 07:35 PM
yeroc1313
Dec 2, 2003 06:35 PM
