Fuse Problem?
Old Jun 26, 2007 | 02:20 PM
Paul*DC4's Avatar
Default Fuse Problem?
This probably a real easy simple solution problem, but i'll admit it, i don't know what a dead fuse looks like. This kid i was driving home from the skatepark decided it would be cool to stick a screwdriver in where the ciggarette lighter goes, hit the back of it, and now my headunit won't go on, it's totally dead, is it just a fuse, and if it is where would it be located..sorry about another DUMB question..
Old Jun 26, 2007 | 03:59 PM
Paul*DC4's Avatar
I wired up a different headunit but it doesn't come on...but power goes to it(the stock acura headunit has a small red light that flashes)
Old Jun 27, 2007 | 06:34 PM
czer47's Avatar
Default Re: (Metalbikes666)
Ok look under your dash board were all the fuses are I had this problem in my own car now you will see a 15 volt fuse witch I think is the red one now remove it and look through it all perfectly fine fuses will look like a horse shoe a blown one will not it will not connect all the way through
Old Jun 27, 2007 | 08:44 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (czer47)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by czer47 &raquo;</TD></TR><TR><TD CLASS="quote">Ok look under your dash board were all the fuses are I had this problem in my own car now you will see a 15 VOLT FUSE witch I think is the red one now remove it and look through it all perfectly fine fuses will look like a horse shoe a blown one will not it will not connect all the way through</TD></TR></TABLE>
Fuses are measured in amps not volts. check the fuses under the dash and the 15 amp fuse under the hood. One of those is blown.
Old Jun 27, 2007 | 09:09 PM
fireman mike2288's Avatar
Default Re: Fuse Problem? (Metalbikes666)
there should be just alttle latch that will say fuses just open that and find the one thats blowin and replace it there not hard to spot
Old Jun 28, 2007 | 08:11 AM
Paul*DC4's Avatar
Default Re: Fuse Problem? (fireman mike2288)
yeah i found it! wow i feel like a retard. it was a 15amp. haha thanks guys!!
2005 TSX
Acura TSX
Mar 6, 2015 07:10 PM
eg grom
13
Oct 22, 2009 09:44 PM
eg grom
Oct 11, 2009 11:43 AM
Pacific
May 7, 2006 08:29 AM
