fuse keeps on blowing
Old Jun 2, 2008 | 08:06 PM
kelviiv's Avatar
Default fuse keeps on blowing
my cluster lights, dash, etc do not work.
the 15 fuse amp keeps on blowing once the car is turned on.
how can i figure out whats wrong?
Old Jun 2, 2008 | 09:22 PM
honda1982's Avatar
More than likely you have a Short somewhere. It's a bitch looking for it.
Old Jun 2, 2008 | 10:43 PM
adam081904's Avatar
Default Re: (honda1982)
Have you done anythinge to any of those items? If you have start from there. Does it blow as soon as you turn your car on? Or does it blow like when you turn on your lights?
Old Jun 2, 2008 | 10:49 PM
kelviiv's Avatar
blow when i turn on the car.
Old Jun 3, 2008 | 04:53 AM
2ndgentegracer's Avatar
Default Re: (kelviiv)
If you have installed, or someone else installed an aftermarket radio in the car, check the wiring back there. I had a problem with mine and when I would shift hard it would blow the fuse, due to a wire touching the exposed metal back there.
Old Jun 3, 2008 | 08:56 AM
kelviiv's Avatar
will do,
S33
Dec 27, 2014 10:22 AM
401RIguy
Mar 13, 2009 07:25 AM
sleeperrex
Aug 24, 2008 04:12 PM
ludesrv
Jun 26, 2007 08:03 AM
2camsaam
Mar 12, 2003 03:55 AM
