Fuel Pump question/help
Old Apr 2, 2010 | 05:09 AM
2kgsrt's Avatar
Default Fuel Pump question/help
Ok so i am pretty sure that my fuel pump is about to take a **** and i wanna replace it before that happens. I hear the loud tea kettle noise coming from behind/underneath the car that is why assume it is the fuel pump. My question is can anything else be making that noise and also what is a good fuel pump that you guys may have used in the past and are satisfied with. I am currently looking at the Walbro 255 HP.
Old Apr 2, 2010 | 07:35 AM
2kgsrt's Avatar
Default Re: Fuel Pump question/help
bumpp
Old Apr 2, 2010 | 07:41 AM
WDG_729_ITR's Avatar
Sounds like you've diagnosed the problem correctly...check out this article.
http://www.wisegeek.com/how-do-i-kno...-fuel-pump.htm
--Also, the Walbro 255 fuel pump is fine choice...I used it in my last car and it worked fine, my friend is even running 2 of them in his car.
Old Apr 2, 2010 | 09:04 AM
2kgsrt's Avatar
Thanks alot, the article pretty much confirmed that it is my fuel pump, but I am going to change the fuel filter aswell just in case it is going bad or goes bad after a few weeks. Thanks again
jlong17crx
Dec 20, 2007 09:08 AM
Ricey McRicerton
Dec 12, 2003 01:28 PM
NastyVtec
Nov 20, 2003 03:06 AM
