fuel pump??
Old Sep 9, 2006 | 04:09 PM
slowassciv33's Avatar
Default fuel pump??
ok i swapped the motor went to turn it ova the fuel pump primed but while priming the check egnine light flashed on and off fast and not very bright. after that it hasnt primed, i changed the main relay and check all the fuses and thng else i should check b4 i remove the pump.i dont wanna buy a pump if it still good
Old Sep 9, 2006 | 04:31 PM
atg1290's Avatar
Pull the code.
Old Sep 9, 2006 | 04:45 PM
Default Re: (atg1290)
thier isnt a code the light flashed on and off very fast and now the check engine light doesnt even go on at all...
Old Sep 11, 2006 | 09:55 AM
Default Re: (slowassciv33)
bump i have no power to the pump and the main relay is new
Djfox
Apr 20, 2018 11:13 AM
EfSedanLove
17
Jan 22, 2007 07:15 PM
Siegfried
Aug 21, 2006 11:17 AM
5genhatch
Aug 6, 2005 05:39 AM
warchild69
Mar 28, 2004 09:27 AM
