fuel filter problems
Old Feb 23, 2006 | 04:18 PM
standinghollow's Avatar
Default fuel filter problems
I was going to finally change my fuel filter that has been long overdue.I went to loosen
the bolt on the bottom and found that the head is half stripped.Im afraid to try to get it off and end up not being able to get it back on tight.So im looking at getting a new fuel line.I just wanted to know if I need this one here?Its number 12 in the pic.
http://www.acuraoemparts.com/d...l=All
Modified by standinghollow at 1:36 AM 2/24/2006
Old Feb 23, 2006 | 09:15 PM
Default Re: fuel filter problems (standinghollow)
anyone else have this problem?
Old Feb 23, 2006 | 09:36 PM
IN VTEC's Avatar
Yeah, it's #12 in the picture.
But, have you tried filing the compression nut to get back to parallel faces and sharp edges? You may have to use a comparable standard or a size smaller metric line wrench afterwards, but it'll save you from having to replace the entire hard line from front to back.
Old Feb 24, 2006 | 12:11 AM
integra3586's Avatar
what kinda wrench are you using? just a normal box end? if so put it down and use a line wrench, that is what they are made for. if you use a line wrench chances are pretty good you'll get it off and back on
Old Feb 24, 2006 | 03:47 PM
Default Re: fuel filter problems (B18B-SC)
Thanks gus ill try it here in a few weeks while im swapping my gsr motor in.
Old Feb 25, 2006 | 08:48 PM
vue_moua's Avatar
had the same problem, bottom fuel bolt was stripping, so i just took a vice-grip twisted the ******. with another wrench holding the other of course.
Old Feb 26, 2006 | 10:49 AM
Default Re: fuel filter problems (vue_moua)
didnt have a problem getting it back on?
Old Feb 26, 2006 | 03:06 PM
vue_moua's Avatar
nope.
Ti3d in
Jul 27, 2004 07:57 PM
VisualEcstasy
12
Mar 17, 2003 10:33 AM
AK94GSR
Aug 7, 2002 08:02 PM
GsrSdn
Jul 27, 2002 04:40 PM
Mikey3000
May 7, 2002 04:18 AM
