Front End Shake
Old May 7, 2006 | 10:58 PM
whitelightningls's Avatar
Default Front End Shake
I have a 94 LS and i just did H&R sport springs and KYB GR2 Shocks and struts and 2 weeks after instal i noticed a shake coming from the passenger front wheel i checked the basics lug nuts, tire balance, ball joints tie rod ends wheel bearing and all checked out fine both axles were replaced about 4 months ago with new honda ones then i noticed the inner wheel well had rub holes and the other side didn't so my question is did my 2 week old strut blow out already??? i realize now the GR2's were a bad choice but im looking for any sugestions on what my problem might be PLEASE HELP!!!
Thanks, Matt B
Modified by whitelightningls at 12:32 AM 5/8/2006
Old May 8, 2006 | 05:03 PM
any ideas???
Old May 8, 2006 | 05:10 PM
Lan's Avatar
Lan
Default Re: (whitelightningls)
Quit bumping your ****. Someone will get to you when they feel like it. Just messin with you. OK have you had an alignment done since you've replaced these parts? Your toe and alignment is most definately the issue if you haven't. If you have check your tires; could one of them be low on air pressure? You could have a bubble in one of the tires as well.
Old May 8, 2006 | 05:27 PM
no alignment but tires and tire preasure are fine if it was alignment wouldnt it have done it from the start??? not 2 weeks later plus im not talkin about a little shake barely noticible this mother is a bad vibration
Old May 8, 2006 | 05:30 PM
Lan's Avatar
Lan
Not necessarily. Is their any evidence of tire wear?
Old May 8, 2006 | 05:32 PM
not so much
Old May 8, 2006 | 05:35 PM
Lan's Avatar
Lan
Whenver the suspension is modified on a car it is necessary to get your alignment checked. I have aligned my car 3 times in the past year because I have changed to height, the struts bought a camber kit. . Every time I changed a part I noticed a vibration of some sort on the freeway. At what speed is the vibration occuring?
Old May 8, 2006 | 05:38 PM
its at all speeds but its very inconsistant plus would the alignment make the tire rub the inner wheel well
Old May 8, 2006 | 05:49 PM
Lan's Avatar
Lan
Look at your tires then. Does it get worse at higher speeds?
Old May 8, 2006 | 05:55 PM
thats the thing it does and doesnt like i said it is very inconsistant sometimes its fine most of the time its terrible unless i put it to the floor and redline every gear then i only notice it once i hit 4th but normal shifting its there from 1st to 5th plus the car seems to be tracking fine i know i should get an alignment but the week after i put in the suspension a close familly member passed away and ive been a little side tracked at this point i dont want to wast the money to have to do it again later
Old May 8, 2006 | 06:09 PM
R-81DC2's Avatar
make sure your lugnuts are tight
Old May 8, 2006 | 06:11 PM
that was the first thing i checked
Old May 8, 2006 | 06:12 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (R-81DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-81DC2 &raquo;</TD></TR><TR><TD CLASS="quote">make sure your lugnuts are tight</TD></TR></TABLE>
and the First thing he obviously didn't read
What did you mean by not getting an alignment yet,
and then not wanting to do it if you have to again?
Old May 8, 2006 | 06:13 PM
^^^ true... ... i meant that i dont want to get it aligned if i have to pull it all apart to change something i think it might be the strut so that means another alignment i will prob upgrade to AGX's or Illuminas
Blaze45
Jul 23, 2015 01:56 PM
don totoro
18
Apr 24, 2010 03:39 AM
rexracerboy
Suspension & Brakes
16
Oct 28, 2009 12:29 PM
nocturnaldragon
Honda Motorcycles
Aug 18, 2008 10:27 AM
pyro_freak8
18
Mar 10, 2004 03:49 AM
