Front end greasing
Old Sep 13, 2005 | 05:31 AM
WRTEG's Avatar
Default Front end greasing
anyone know where all the nozzles/dimples are on the 94-01 integra front end to regrease everything? i.e. ball joints......
searched and can't find anything
Old Sep 13, 2005 | 05:32 AM
Rajin's Avatar
Default Re: Front end greasing (94IntegraNL)
Need a little more info, are you regreasing CVs on axles as well?
What all do you want to grease?
Old Sep 13, 2005 | 05:35 AM
Jrfish007's Avatar
Default Re: Front end greasing (Rajin)
Well, I want to grease everything that needs greased... I thought most Honda's by the 90's where sealed by the factory and never needed grease.
Old Sep 13, 2005 | 05:39 AM
WRTEG's Avatar
im bringing the car out in the garage now in a bit, i plan to regrease "everything i can", got a grease gun and some grease, all ready to go. just need to find all the nozzles
Old Sep 13, 2005 | 05:40 AM
WRTEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rajin &raquo;</TD></TR><TR><TD CLASS="quote">Need a little more info, are you regreasing CVs on axles as well?
What all do you want to grease?</TD></TR></TABLE>
yep i would be putting a extra little bit in my cv's as well
Old Sep 13, 2005 | 06:53 AM
Rajin's Avatar
go for it, Will be good for the car, give you a chance to check your Joints on you CV axles anyway
Old Sep 13, 2005 | 10:53 AM
ProjectLSVTEG's Avatar
last time I checked... hondas had sealed chassis. At least by the early 90's... I've worked at Jiffy Lube, Express Lube, and now Midas, and have never once greased a honda chassis.... I'm aboout 99% sure you can't do it.
If it is squeeking, I'd suggest looking at your bushings, and possibly upgrading to polyeurathane (one of my many soon to come mods).
Old Sep 13, 2005 | 11:12 AM
Tweakmeister's Avatar
Default Re: Front end greasing (ProjectLSVTEG)
There are no Zirc, or other "lube" fittings anywhere on the 3rd Gen Integra. The only thing for you to grease are the door hinges, and even those can go without it just fine.
The CV's, Balljoints, Tierods, etc are all sealed and should be replaced if the boot is cracked (you should wash and keep them clean to help prolong life).
Old Sep 13, 2005 | 11:23 AM
2G0S0R1's Avatar
New User
Default Re: Front end greasing (Tweakmeister)
Correct.
If you want to squirt a little silicone/lithium lube on your bushings and such it will help with squeeeeks a little bit.
Where i live when it rains the streets flood to like 6 inches and i have to get to work. I wish i had a beater but i dont. After the rains my car always squeeks from the dirt and water and residue. I blast them all out with the hose, regrease/spray-lube and it is good as new... almost...
Friggen San Fernando Valley Streets, its almost like New Orleans sometimes. Well, not really, sorry bad joke.
Old Sep 13, 2005 | 11:34 AM
Default Re: Front end greasing (2G0S0R1)
FYI Apparently White Lithium Grease doesn't mix with aftermarket Silicone (ES, etc.) bushings.
Normal rubber should be fine.
mcgee*
Jun 5, 2006 07:42 AM
TylerC
Nov 6, 2005 08:34 AM
BrownGSR
Nov 20, 2003 11:05 AM
Jonathan_ED3
Aug 26, 2003 03:38 PM
ILOVEGIRLS
Aug 9, 2003 09:16 AM
