fried piston ring
Old Aug 11, 2011 | 04:14 PM
dyce_b17's Avatar
Default fried piston ring
hey i have a 93 integra gsr, i plan to keep the b17 and build it semi-all motor in the future, but i just found out my 2center pistons are fried, i was thinking bout a new set of "Arias piston" same 81mm but 11:6 high cp. my question is would it work wit my stock rods and stock head set-up?
Old Aug 11, 2011 | 05:29 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: fried piston ring
depending on the condition of the cylinders and how bad there scored or scratched you should at least go 81.5mm and you can re use the rods, iv used them plenty of times with alll motor setups like the last one i built that hit 216hp on stock rods and pistons. If you run cams to bring up the power make sure you use the proper matching valve springs and retainers to the cam shaft. other wise you can use a stock head no problem just use ARP studs to ensure you get a solid seal when the head is torqued and that it wont lift during the dyno or when ran hard. Look into stroking that block to a 1.9l or if you have the money. other wise its a 1.7l, better than the b16 thats a 1.6l but not better than a gsr/itr thats a 1.8l.
Old Aug 13, 2011 | 12:44 PM
dyce_b17's Avatar
thanks ill look into it some more.
crxfreak1117
Jul 5, 2007 10:03 PM
tempsohc
Nov 21, 2006 10:32 AM
del_slow420
Jul 27, 2006 08:58 AM
sprayedlude93
Jan 6, 2006 12:56 PM
blazin
Oct 10, 2002 01:33 PM
