FREAKIN PLEASE HELP
Old Jan 7, 2006 | 07:31 PM
b20integrapower's Avatar
Default FREAKIN PLEASE HELP
i got a pr4 for my integra...its a 96 rs witha b20b in it...i was told the pr4 was obd1 and i have an obd2 to obd1 jumper harness...it connects and works..but the idle is really crappy...it idles at 500 rpms...and if i give it gas and let go...the idle drops to 100 rpms...and comes back up...it dropped so low once that it shut off and wouldnt turn back on unless i cranked it with my foot on the gas pedal...PLEASE HELP
Old Jan 7, 2006 | 07:45 PM
Default Re: FREAKIN PLEASE HELP (b20integrapower)
wow...no one? cmon guys...
Old Jan 7, 2006 | 07:49 PM
.water's Avatar
adjust the idle??
Old Jan 7, 2006 | 07:51 PM
Default Re: FREAKIN PLEASE HELP (TuneZero)
my friend messed with it...but he just kept movin it around...wat way should i adjust it?
its the little flat head screw lookin thing on the tb right?
Old Jan 7, 2006 | 09:20 PM
Rikter's Avatar
take it to someone who knows what their doing with the car ( dealership ). Sure you may pay a bit but hopefully they'll fix it. You can have em only diagnose and troubleshoot for an hour. Might as well have em fix it instead of a friend "movin it around " and probably making things worse.
-Rik
Old Jan 7, 2006 | 09:35 PM
LoseRPunKx182's Avatar
are u sure that's the right ecu u want to run
Old Jan 8, 2006 | 12:14 AM
Default Re: FREAKIN PLEASE HELP (LoseRPunKx182)
took the pr4 back..got a p75...and the idle is weird until it warms up and runs perfect
the p75 is also for an auto...so i dunno if thast why the idle is kinda weird..but not as bad as the pr4
Old Jan 8, 2006 | 01:43 AM
Groove_D's Avatar
I had the same problem actually, but it was the ECU.
Old Jan 8, 2006 | 08:48 AM
LSvtec03's Avatar
Default Re: FREAKIN PLEASE HELP (Groove_D)
is the throttle cable too loose?
catdaddy77
Feb 16, 2009 06:03 AM
es.roadster
Jan 24, 2009 11:19 PM
pork
Sep 24, 2007 09:46 AM
vr_civic
Jun 15, 2005 06:03 AM
