does Vtec controller really help? is the $300 worted?
Re: does Vtec controller really help? is the $300 worted? (97coupe)
If you are talking about VAFC, then it depends on the mods to your car. The VAFC also controls A/F ratio and probably other features(not sure...don't have one)
Re: does Vtec controller really help? is the $300 worted? (shermanyang)
its worth it if you have enough mods to tune it on a dyno.. i know the VAFC helps me out alot when im on the track racing cause i can set the vtec engagement..
with mods set up for tuning such as cams, timing, fuel pressure.....vtec tuning is worth it....
and these days you can get the old version vafc for well under 300....try looking around..some places are getting rid of them cheap to make room for the version 2's
plus...it looks cool and keep you occupied in traffic or at a red light...kekeke
Re: does Vtec controller really help? is the $300 worted? (Hybrid95CivicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid95CivicEX »</TD></TR><TR><TD CLASS="quote"> i know the VAFC helps me out alot when im on the track racing cause i can set the vtec engagement.. </TD></TR></TABLE>
Idealy, if you have a non-stock, aggressive cams, you can increase the engement or decrease to suit your cams. On stock cams, OEM specs are the best.
I have a Field and don't get me wrong, its pretty cool. I increased the fuel a little on top end, but that isn't doing that much. Id say find one used........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97coupe »</TD></TR><TR><TD CLASS="quote">is it really worted to spend $300 on a Vtec controller? </TD></TR></TABLE>
check the sponsers marketplace, a company is selling them for $250 brand new shipped . this is a really good price
Re: does Vtec controller really help? is the $300 worted? (EF8_Fan)
anyways they are a cheap way of tuneing your car !!... and will not do you as good as a hondata !! witch is in the same price range !
D Tranny Guru
for $75, burn your own chips, make VAFC totally useless at 1/4 the price.
VTEC at 4600
target idle at 850 rpm
-15% fuel on low cam
-10% fuel on high cam
I'm running 325 cc injectors BTW.......
VTEC at 4600
Re: does Vtec controller really help? is the $300 worted? (Zeus Zore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zeus Zore »</TD></TR><TR><TD CLASS="quote">anyways they are a cheap way of tuneing your car !!... and will not do you as good as a hondata !! witch is in the same price range !</TD></TR></TABLE>
get hondata
get hondata
4DRB18C1
12-03-2001 01:14 PM
