fly-wheel
Old Dec 20, 2005 | 10:39 AM
petergriffen's Avatar
Default fly-wheel
ok i've heard different things. does a light wieght fly-wheel lower your torque, or does it make you gain torque ? i know it helps with accleration and horses.
Old Dec 20, 2005 | 01:16 PM
XYU's Avatar
XYU
Ask me about vaginal warts
Default Re: fly-wheel (petergriffen)
yeah, that would be interesting to now for me as well.
Old Dec 20, 2005 | 01:26 PM
DirtyBirdJR's Avatar
Default Re: fly-wheel (DC4 B20)
it shouldnt affect hp or tq of the motor
Old Dec 20, 2005 | 01:34 PM
projectTeG's Avatar
https://honda-tech.com/zerothread?id=949790
https://honda-tech.com/zerothread?id=1016532
https://honda-tech.com/zerothread?id=1023138
all found in the faq in the top of the integra forum.
Old Dec 20, 2005 | 02:09 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: fly-wheel (DirtyBirdJR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyBirdJR &raquo;</TD></TR><TR><TD CLASS="quote">it shouldnt affect hp or tq of the motor</TD></TR></TABLE>
A lighter flywheel has a lower rotational inertia, which increases your acceleration. Since the engine is more reactive with the lower rotational inertia, pulling out can be more difficult than with a heavier flywheel.
Old Dec 20, 2005 | 03:40 PM
Default Re: fly-wheel (Dogginator)
so it does put a damper on your torque to a point?
Old Dec 20, 2005 | 05:34 PM
nObOdy65's Avatar
You wont lose torque or hp.
Your car will rev faster and will actually be faster - you will free up hp and torque so you will gain both and it will be at different levels throughout your gears.
here - have fun with this.
Q: Many people say that lightweight flywheels can save power and increase performances (eg. on 300ZXTT: "Each lb. Of mass taken off the crank/eccentric shaft is worth approximately 2.7 hp"). OK, I know that the lower the weight of the car, the best the ratio weight/power. But with lightweight flywheels, you can save only a few pounds and the car is around 3000 pounds so the driving performances should be very low... I read that rotating mass has more important impact than others. Is that right? And why?
Sarah: I should have never ditched those physics lectures back in college. Although a lightened flywheel does not increase horsepower, you've got the right idea- decreasing mass and rotational inertia will free up power quicker. Inertia is the property of matter resisting a change in motion. The flywheel resists a change in the speed of rotation of the driveshaft, consuming power during acceleration. A flywheel has mass and inertia. Click for Full Image It takes torque, the rotational equivalent of force, to start and stop its turning. The rotational equivalent of mass is the moment of inertia. The more mass an object is, the harder it is to get it to start or stop moving. Moment of inertia depends on the mass of an object and where it is concentrated close to the axis of rotation. Think of the flywheel as a disc. This oversimplifies the properties of a flywheel since a flywheel is not a homogenous mass but thicker in the center than the edges. However, it will make calculations easier to understand and still offers a good estimate. The formula for the moment of inertia, I, is: I=0.5mr^2. Holding r constant since the size of the flywheel is not changing you'll notice mass has a large effect on the moment of inertia. Substitute rotational equivalents for straight-line motion variables in Newton's second law of rotation to determine the amount of force exerted on an object. Use torque for force, moment of inertia for mass, and angular acceleration for acceleration.
If moment of moment of inertia (mass) decreases, less torque is needed to keep the acceleration variable the same. If the same torque is applied, the angular acceleration increases. Now that you've gotten the Physics 101 lecture, let's take this to a more advanced level course. Let's apply this to the 1993 Sentra which weighs about 2,500 pounds and makes about 140 horsepower at 6400 rpm in 3rd gear. Using 3rd gear and final drive ratios, the 3rd gear wheel rpm is 1192 (6400 rpm x 1.286 3rd gear ratio x 4.176 final gear ratio). Calculating for 3rd gear torque and assuming a stock tire radius of 175mm (0.574 feet), this gives a forward rate of acceleration of 0.43 g, or about 13.8 ft/sec^2. Angular acceleration, or how fast the rate of rotation of the flywheel is changing, is 24.1 rad/sec^2 (linear acceleration/tire radius). Multiplying this by 3rd gear ratio and by the final drive ratio, the flywheel is accelerating at 129.4 rads/sec^2. The stock flywheel weighs 18 pounds and is about 0.365 feet in radius, giving a moment of inertia of 0.0434. Flywheel torque is the flywheel angular acceleration times the moment of inertia, or 4.8 ft/lbs and the power consumed by the flywheel is torque times angular velocity, or 5.86 hp. Changing the flywheel weight to a 9 pound lightened flywheel from Unorthodox Racing while holding all other variables constant, the flywheel only consumes 3 hp, freeing up 3 hp in 3rd gear. A lightened flywheel frees up more power in the lower gears since it is harder to begin momentum that to continue it. Solving for 1st and 2nd gears, the lightened flywheel frees up 16 hp in 1st and 6 hp in 2nd. Gains in the higher gears are negligible, 1.7 hp in 4th and 1 hp in 5th.
A car with a heavier stock flywheel will obviously benefit more from a lightened one. The Spec V flywheel weighs in at almost 29 pounds, a heavyweight in the Nissan lineup. Switching to the 12 pound Jim Wolf Technologies flywheel will free up 16 hp in 2nd, 7 hp in 3rd, 4 hp in 4th, 2.5 hp in 5th, and 2 hp in 6th. Amazing, the stock QR flywheel consumes 50 hp more than the lightenend one in 1st gear! It revs happier and has more pickup than a Playboy bunny at a Wall Street bar during happy hour! This engine is already a torque monster so invest in sticky tires to make the most traction of that power.
Since a flywheel absorbs some of the energy generated by the engine during acceleration, lightening the flywheel increases the torque on the driveshaft since less energy is used to accelerate it and more is used to turn the drivewheels. Keep in mind it's not just how much mass is removed from the flywheel but where it is removed. The concentration of mass affects how much resistance the flywheel offers to changing rpm. Rotational inertia increases with the square of the distance of the axis or rotation. Removing weight on the edge of the flywheel is 4 times as good as from the midpoint between the center and the edge. Finally, a flywheel will not show much of a gain in horsepower on a dyno because it doesn't increase fuel or air and can't increase horsepower. Remember, you're not actually improving your car's power, just how quickly it can get to to that power. An inertial dyno will show gains by the engine reaching a predetermined rpm sooner with a lightened flywheel.
Old Dec 20, 2005 | 06:30 PM
LSvtec03's Avatar
Default Re: (nObOdy65)
damn, thank you! you do NOT lose torque from a flywheel.
Old Dec 20, 2005 | 07:03 PM
DAcraze's Avatar
Default Re: (LSvtec03)
true no torque will be lost from a lightweight flywheel. if u get a lightweight flywheel u are just decrasing ure rotational mass. your torque will not be affected
Old Dec 20, 2005 | 08:35 PM
Muckman's Avatar
Moderator in Chief
Default Re: (DAcraze)
wow a bunch of pro-lightweight flywheel answers in the Integra forum. Im impressed.
Old Dec 20, 2005 | 10:01 PM
LSvtec03's Avatar
Default Re: (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">wow a bunch of pro-lightweight flywheel answers in the Integra forum. Im impressed. </TD></TR></TABLE>
why?
Old Dec 20, 2005 | 10:24 PM
Muckman's Avatar
Moderator in Chief
Because most light FW threads in this forum end up with everyone saying how they cause stalling, or reduce torque, or reduce the load, on the engine and add turbo lag, are not streetable blah blah blah alot of myths. You get the idea.
Old Dec 20, 2005 | 10:49 PM
lVlemphizStylez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">and add turbo lag.</TD></TR></TABLE>
lmao dunno why but i laughed hard when i read that
Old Dec 21, 2005 | 05:37 AM
Muckman's Avatar
Moderator in Chief
Default Re: (lVlemphizStylez)
lol some ppl think less rotational mass will not generate as much "load" on the engine therefore wont spool the turbo as fast. The crap some people dream up. Flywheels probably have more myths than any other aftermarket part.
Old Dec 21, 2005 | 06:56 AM
BuyImports2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Because most light FW threads in this forum end up with everyone saying how they cause stalling, or reduce torque, or reduce the load, on the engine and add turbo lag, are not streetable blah blah blah alot of myths. You get the idea.</TD></TR></TABLE>
People mis-interepret things, however, they aren't always just making things up.
A lighter flywheel stores less rotational energy. This means that when you let the clutch out, less energy is being transferred to the wheels (THIS IN NO WAY MEANS THAT YOU HAVE LESS TORQUE). With less power to the wheels, you will be more likely to stall the car if you are not used to having a light flywheel. This is probably where the "they cause stalling" and "are less streetable" talk comes from.
The only power loss you experience is from when you are dropping the clutch, and this can be countered as long as you are familiar with the "gas pedal". I'm sure most of you are...lol
If you are thinking, "oh crap, less power when I drop the clutch? my car must be slower!!", then you would be wrong. The fact that a lighter flywheel stores less energy is a good thing. Basically it means that your engine will be able to accellerate faster, becuase the energy is going to the wheels instead of being stored in the flywheel.
86crxintheworks
May 19, 2008 03:31 PM
KnuckleZ
Feb 27, 2006 12:01 PM
madlion
Oct 25, 2004 06:50 PM
AllMoToRB18c
Sep 23, 2003 10:00 PM
